need help, choosing to stay with my klipsch rf-52s or going to energy cf-70 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-27-2013, 08:20 PM - Thread Starter
solarg37's Avatar
i have a oportunity to upgrade my klipsch rf 52s front and center speakers to energy cf series
currently i have rf 52 ii and rc 52ii and would be going to energy cc10s and rc 70s
my main thought are i would be going to a 3 day system instead of a 2 way with klipsch and i would get a cleaner sound from the dome tweeters
also bigger bass drivers
dont get me wrong i love my klipsch's and still not 100% if i should do the move ?
what are your guys thoughts?
stick with the klipsch or move to energy ?
thanks for all your help
solarg37 is offline
post #2 of 16 Old 02-27-2013, 08:30 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Well even though I haven't heard either, I know they sound drastically different.
By the way, you need the RC-LCR center which goes for like 400-500$..
I would say it would be more of a lateral move in terms of sound quality. More experienced peoples will probably chime in.
GaryWA is offline
post #3 of 16 Old 02-27-2013, 08:34 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
If you love the Klipsch then dont move. There is no point. Just because you see a new TV 70% off..but your current TV is in great shape and you like it...don't go buy the TV just because it is a "good deal".
Save your money for something else.
Newbie01 is offline
post #4 of 16 Old 02-27-2013, 08:37 PM - Thread Starter
solarg37's Avatar
thanks for you input i can go with the rc lcr center instead and go with the cf 70 for the towers,
i know they will sound differently in a good or bad way =<, i wondering if its worth the trouble ?
speakers will be ran off my yamaha aventage a2000 ,
solarg37 is offline
post #5 of 16 Old 02-27-2013, 08:40 PM - Thread Starter
solarg37's Avatar
i also might have a chance to pick up some monitor audio rs6 used also,
solarg37 is offline
post #6 of 16 Old 02-27-2013, 08:42 PM
Macstatic's Avatar
The RC-LCR center is from a totally different series than than the CF-70. Different sound and different look. I've had the CC-10 (center that matches the CF-70) as well as the CF-70s. I also currently have the RC-LCR with my other Energy RC speakers.
The CF-70 is the best of that series as far as sound goes. It is a little bit bright which makes it good for movies. The RC speakers are discontinued so getting those would be difficult but generally the CF towers would be better for movies and RC better for music. Although I love my RC speakers for both. Higher quality than the CF towers.
For those looking into getting Energy speakers, or upgrading their current Energy setup, here are some reviews I've written that may help:http://www.tempestaudio.blogspot.com  (haven't updated in a while, but include Energy Take Classic 5.1, RC-10, CF-70, and CC-10)
Macstatic is offline
post #7 of 16 Old 02-27-2013, 08:44 PM
Macstatic's Avatar
Either go with CF-70 and CC-10
or
RC-LCR and RC-70
post #8 of 16 Old 02-27-2013, 09:04 PM
brendelac's Avatar
Quoted: 148 Post(s)
Liked: 83
http://www.vanns.com/shop/servlet/item/features/548446170/energy-v5-2c?s_c=site_search
People from the Energy thread say that they are happy with a V5.2C in between their RC70s
brendelac is offline
post #9 of 16 Old 02-27-2013, 09:23 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Don't understand why people are fueling your upgradeitis when you are happy with your Klipsch? Newer does not = better especially since you never said you heard the Energy.
Anyway...have fun with whatever you decided.
Newbie01 is offline
post #10 of 16 Old 02-27-2013, 09:25 PM
Macstatic's Avatar
Naw, I really agree though, if you're happy with what you have you keep it. Although if you were wanting to try out a different sound, do what I did: just purchase a pair of bookshelf speakers from that series or manufacturer and try it and then if you like it purchase the bigger speakers in that series and then use those first bookshelves as surrounds or heights or something.
post #11 of 16 Old 02-27-2013, 09:29 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
You need to listen to them next to your Klipsch. I have to say, I am not keen on the Energy CF series. They did nothing for me. Just my opinion..
ack_bk is offline
post #12 of 16 Old 02-28-2013, 12:08 AM - Thread Starter
solarg37's Avatar
Thanks for you input guys
My main point was going from a 2 way to a 3 way system
Also the energy has bigger drivers compared to my rf52
Also going to a dome tweeter instead of a horn design
The main question are these an upgrade move from my rf52s that I have
solarg37 is offline
post #13 of 16 Old 02-28-2013, 09:22 AM
ravingndrooling's Avatar
IMHO, I would say it would be an upgrade going from your Klipsch(RF-52) to the Energys. How much is up to YOU and your ears...I've had a couple different pair of Klipsch as well as a couple different Energy set ups including the center mentioned above....Both very different sounding from each other. If you "love" your Klipsch, stick with them and save yourself the hassle/time/money of changing your speakers out. If you are not happy with your Klipsch, then you WILL NOT stop until they are gone...I've been in your position a few times. I wouldn't worry about the size of the drivers too much, there are plenty of speakers out there that use smaller drivers and have NO problem filling a room and getting LOUD with wonderful sound. I am currently using a 2 way monitor style speaker(with matching center) and they fill my 16X23 foot room with wonderful distortion free sound...So, size ISN'T necessarily better either. I don't know what your room looks or sounds like, but before I would spend more money on speakers, I would make sure my current speakers are placed properly in my room...I spent a couple hours last weekend just moving my speakers around and finding the optimal placement...It DOES make a big difference. Room treatments can have a large effect on your sound as well...Just sayin... In regards to a 3way compared to a 2way design...there are always trade-offs. Personally, I prefer a 2way style monitor WITH a sub. I like the way my monitors just disappear in my room, compared to the "floor standers" that I have had. YMMV
When the going gets weird, the weird turn pro!!
ravingndrooling is offline
post #14 of 16 Old 02-28-2013, 09:35 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
OP, do you have a sub?
ack_bk is offline
post #15 of 16 Old 02-28-2013, 10:45 AM - Thread Starter
solarg37's Avatar
i do have a sub, im runing dual rw12 subs currently
room is a meduim size living room,
i just ran to best buy to hear one in person and they did sound pretty good but they dont carry klipsch reference series in there magnolia section so i couldnt do a side by side comparison
they did sound on the bright side but nothing different then the horns on the klipsch,
solarg37 is offline
post #16 of 16 Old 02-28-2013, 11:18 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Anyway you can buy the Energy towers for an in home demo with the option to return?
I like Energy speakers and own the RC-50 towers. It seems to me what you are contemplating is more of a lateral move within the same speaker class where listening preferences will be the biggest determining factor. These are just different sounding speakers. Some people will like the Energys better; some the Klipsch.
You already said that you like your Klipsch. So unless you can compare the Energy sound side by side with the Klipsch, I would wait until you can make a significant upgrade.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply Speakers
Klipsch Reference Series Rf 52
