Polk R15's or Pioneer SP-BS22-LR and Klipsch sub10 or Pioneer SW-8MK2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-01-2013, 10:02 AM - Thread Starter
reynonic's Avatar
Entry level Front speakers, what ones are better? The center channel for the Pioneer's is easier to find so I was kind of leaning toward those.
90% movies. I dont have the reciever yet, I have 4 TL1's for surrounds right now for a 7.1 setup,
should I get the polk R15's 99$ a pair
http://www.polkaudio.com/products/r15
or should I get the Pioneer SP-BS22-LR Andrew Jones Designed Bookshelf 89.99$ a pair
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=884049&Q=&is=REG&A=details
And for a sub
Pioneer SW-8MK2 Andrew Jones Designed 100-Watt Powered Subwoofer 150$
http://www.amazon.com/Pioneer-SW-8MK2-Designed-100-Watt-Subwoofer/dp/B008NCD2PC
Or a Klipsch sub10 from a local pawn shop used for 150$ (im going to try and get it lower)
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780012
reynonic is offline
post #2 of 2 Old 03-01-2013, 05:16 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
Definitely the Pioneer SP-BS22-LR.
Of these two, probably the Klipsch, but I'm not very familiar with this specific model. If you could stretch to $200, you could get the BIC F12, which is larger and well regarded for that price.
Robert Cook is offline
Reply Speakers
Pioneer Andrew Jones Designed Powered Subwoofer Sw 8mk2 , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr
