Crossovers - Most Likely Component to Fail - AVS Forum | Home Theater Discussions And Reviews
Old 03-02-2013, 03:40 AM - Thread Starter
keicar's Avatar
Hi, new to this to - be patient!
One of my Celestion F30's has lost mid-range, by substitution I have worked out that the problem lies in the cross-over, which has just 5 components, 3 coils and two caps, a 9uf 50v and a 10uf 100v which bridges the MF output.
My question is would the most likely failure be one of the caps? and could I replace the 9uf with a 10uf?
I'm guessing the coils would be almost impossible to replace (.85mh & 6mh)
Thanks for any help.
keicar is offline
Old 03-02-2013, 08:04 AM
Bill Fitzmaurice's Avatar
Liked: 4668
Originally Posted by keicar View Post
One of my Celestion F30's has lost mid-range,.
This explains how crossovers work:
http://www.bcae1.com/xoorder.htm
Bill Fitzmaurice is offline
Old 03-02-2013, 02:28 PM
Pat315's Avatar
How do set crossover for the center channel
Pat315 is offline
