Need help choosing between 3 tower speakers (pair) <$400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-03-2013, 10:09 PM - Thread Starter
shroomsm's Avatar
Hey, so I want to buy tower speakers for under $400/pair and after sifting through all the reviews, I've narrowed it down to three choices:
Infinity Primus p363
HTD Level Two Towers
Boston Acoustics A360
Any input is helpful... The main use of these speakers will be for music.. Also, feel free to throw out other suggestions. Thanks!
shroomsm is offline
post #2 of 14 Old 03-03-2013, 10:12 PM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
Do you have a reason why you want towers? I'm going to assume you don't want to add a subwoofer and are going with towers?
pokekevin is offline
post #3 of 14 Old 03-03-2013, 10:20 PM - Thread Starter
shroomsm's Avatar
i honestly couldn't know less about speakers, but i am only buying either towers and a small sub or bookshelves and a decent sub... not both towers and bookshelves.. from what i've read and heard, towers are a better choice if they're the only source of sound... again, it must be evident i don't know what im talking about, so i am very open to suggestions..
shroomsm is offline
post #4 of 14 Old 03-03-2013, 10:29 PM
nothingspecial's Avatar
Liked: 25
A little bit more than you were looking at $79 more.
Mordaunt Short Aviano 6 towers from Hi Def Lifestyle $479 a pair originally $1,200 a pair.
I don't know of a deal better than that.
http://www.hideflifestyle.com/
nothingspecial is offline
post #5 of 14 Old 03-03-2013, 10:50 PM
Bond 007's Avatar
Quoted: 2650 Post(s)
Liked: 2103
How big is your room?
Licence to Kill
Bond 007 is offline
post #6 of 14 Old 03-04-2013, 05:55 AM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 37
Did you give ML Motion 12's a peak?
Or Pioneers?
Newbie01 is offline
post #7 of 14 Old 03-04-2013, 10:36 AM - Thread Starter
shroomsm's Avatar
My room is approx. 14x14... The Mordaunt Short Aviano 6 towers look great, and there's a chance I can up my budget to $479, but i'd prefer not to... anyone have any info on the Mordaunt's or the three other towers i listed?
shroomsm is offline
post #8 of 14 Old 03-04-2013, 11:36 AM - Thread Starter
shroomsm's Avatar
About to pull the trigger on the Aviano 6's.. any last words? PLEASEEEEE
shroomsm is offline
post #9 of 14 Old 03-04-2013, 12:11 PM
Liked: 25
The Infinity Primus there okay for music if I could get better I would want better. I do like them for movies though if that's what a person was wanting and there's no good deals out there it's good for that. But for music I would want better.
The only Aviano I've heard is a bookshelve model and it's very impressive I would think a tower would be even better since then you would have the bigger fuller sound of a tower and the more stronger satisfying bass.
Really for the price of the Aviano 6 I don't know of a better deal at that price.
That's why I say is there a better deal? Because I would like to know.
If I didn't already have some towers I would of already bought them.
post #10 of 14 Old 08-07-2013, 02:42 PM
powerlifter405's Avatar
Quoted: 103 Post(s)
Liked: 178
What happened?
Stereo Noob, Sherbourn SR-120 pushing 5ch Arx/Chane. JTR 218HT prototype
powerlifter405 is offline
post #11 of 14 Old 08-07-2013, 03:09 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
I just got the JBL ES80 speakers at Fry's for $144 each. They sound amazing in my room and the clarity is sharp and the bass is tight.
sojodave is offline
post #12 of 14 Old 08-07-2013, 03:24 PM
Quoted: 103 Post(s)
Liked: 178
Cool, nothing better than saving some $ and still getting what you want.
post #13 of 14 Old 08-07-2013, 05:20 PM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 143
The Aviano 6 now just $399/pair with free shipping on Amazon.
Gmash is offline
post #14 of 14 Old 08-07-2013, 05:32 PM
Valtyr's Avatar
Liked: 80
If you're looking for music I'd do Cambridge Audio S30's all the way. My favorite speakers in your price range.
My P363's worked fine but they are simply overmatched by the S30 bookshelf speaker. You can add a sub later, they should have enough bass to be serviceable without a sub but you could certainly add a nice sub now since you'll have about $200 to play with.
If you did pull the trigger, what did you get?
Valtyr is offline
Reply Speakers
