I have $2000 to spend on speakers for a 5.1 systems to go with a Pioneer VSX-23THX. Any reccomendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-05-2013, 08:00 AM - Thread Starter
Tyrantdawg's Avatar
Hey all, I am finally upgrading my speakers from the current Theater in a Box ones I have been using. I have a Pioneer VSX-23THX and a paradigm bass, so I only need 5 speakers. I will primarily use my system for watching TV, Movies and playing video games. My system will also be located in my living room, which is pretty standard. Which speakers would you recommend that would give me the best value for my money. Thanks for the help.
Tyrantdawg is offline
post #2 of 4 Old 03-05-2013, 01:38 PM
Kini62's Avatar
Quoted: 1423 Post(s)
Liked: 1316
You're question is too vague.
You need to add some details, like room size, whether or not you want to buy locally, online, ID etc.......
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 4 Old 03-05-2013, 03:52 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Also budget range, space/size limitations, etc.
sdg4vfx is offline
post #4 of 4 Old 03-05-2013, 05:08 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
+1
Yep. Room volume (cubic feet). Do you have room for towers, or just bookshelves? What about the surrounds? Do they have to hang on the wall, or can they go on stands?
And also, which model Paradigm sub do you have to match with your speakers?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply Speakers
