On wall center help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-05-2013, 11:25 PM - Thread Starter
premium0521's Avatar
Hey guys. Right now I have some small onkyo lcr speakers from an old htib setup. I've gotten a new receiver (denon1913)so it's time to upgrade speakers. I can't do all three at once and my wife has a hard time hearing dialog so I want to start with the center. It has to be on wall and not crazy expensive.
I've been looking at
Klipsch g28
Definitive tech xtr 40 or 50
Paradigm cinema 400
Open to any other suggestions too!
Which would be the best for dialog?
I've seen the klipsch as low as 200. I haven't check prices on the others in a while.
premium0521 is offline
post #2 of 6 Old 03-06-2013, 09:40 AM
flickhtguru's Avatar
Liked: 110
Check out these. Buy 3 of them for your front 3 speakers. These things are great for really bringing dialog out.
http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=1765&sc=33
Shawn
flickhtguru is offline
post #3 of 6 Old 03-06-2013, 10:47 AM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
I'm not that familiar with on-wall speakers, but you may want to look into these:
http://www.emptek.com/onwall.php
Robert Cook is offline
post #4 of 6 Old 03-06-2013, 11:09 AM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3554
Klipsch g28
Paradigm cinema 400
Have you considered a sound bar?
mjgarrett100@gmail.com
Mike Garrett is offline
post #5 of 6 Old 03-06-2013, 10:39 PM - Thread Starter
Thanks for the suggestions. Are the empteks a quality speaker. I haven't heard of them before.
I haven't thought about a sound bar. Why do you recommend one? Any inparticular?
post #6 of 6 Old 03-07-2013, 01:36 PM
Quoted: 34 Post(s)
Liked: 55
I only know of these on-walls by reputation, but theirs seems to be a good one. I'm sure you'll find some firsthand experiences and reviews if you do a search.
Reply Speakers
