Newbie needs help setting up Pioneer SP BS22 speakers, SW 8 MK2 sub, and lepai amp - AVS Forum | Home Theater Discussions And Reviews
Old 03-07-2013, 12:11 AM - Thread Starter
IJ300's Avatar
I just received my brand new speakers, amp, and sub. However, I did not buy any speaker wire or RCA cables. I'm totally new to this, and I need a little help choosing which stereo wire and other accessories I need for a set up that will work well with my desk top computer.
Is all speaker wire the same? Should I just go to Amazon and choose any type of speaker wire?
Any help is appreciated, and I would like it if you'd post links to the equipment I need.
Here are some pics:
Lepai
Amp
Speakers
IJ300 is offline
Old 03-07-2013, 12:40 AM
GusGus748s's Avatar
Quoted: 389 Post(s)
Liked: 695
14 or 16 guage wire should work fine. I am not sure how you are going to connect a subwoofer to that amp since it doesn't have a subwoofer connection. I think it can be done, but I am not sure how.
GusGus748s is offline
Old 03-07-2013, 01:02 AM - Thread Starter
IJ300's Avatar
Thanks for the help. Excuse my ignorance, but can't I use an rca cable to connect the amp to the sub?
IJ300 is offline
Old 03-07-2013, 08:13 AM
afrogt's Avatar
Quoted: 788 Post(s)
Liked: 626
No, because the Lepai amp doesn't have a subwoofer output. Those RCA jacks on the Lepai are audio inputs, not outputs.
I have two Lepai amps so I know this unit very well.
Afro GT
afrogt is offline
Old 03-07-2013, 08:18 AM
afrogt's Avatar
Quoted: 788 Post(s)
Liked: 626
You need this Lepai amp which has two sets of speaker terminals and one set of line outputs.
http://www.amazon.com/Lepai-LP-269FS-Watts-Amplifier-Remote/dp/B0073WTG6M/ref=pd_sim_e_3
Afro GT
afrogt is offline
Old 03-07-2013, 08:42 AM
cel4145's Avatar
Quoted: 1779 Post(s)
Liked: 2134
Yes. This can work.
You need a splitter that can run the sound from your computer to your Lepai AND your subwoofer. Then connect your speakers to the Lepai.
Once you have that hooked up, you'll have to balance your Lepai and subwoofer volumes, and from then on, use the main volume control on your computer.
Living room HT: Energy RC-50 & RC-LCR, Ascend CBM-170 SE, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: Sierra 1 | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Old 03-07-2013, 09:43 AM - Thread Starter
IJ300's Avatar
thanks for the help. Do you have a link or a picture of the particular splitter I need?
IJ300 is offline
Old 03-07-2013, 12:59 PM
jtothar's Avatar
Originally Posted by cel4145 View Post
Yes. This can work.
Am I nuts or does his sub have line level inputs on it? Cant he just run a set of speaker wires from the lepai to the line level inputs on the back of his sub?
jtothar is offline
Old 03-07-2013, 01:34 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
Use one of these to split the audio signal from your computer:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021808&p_id=667&seq=1&format=2
One of these to connect from the splitter to the amp:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021802&p_id=644&seq=1&format=2
And one of these to connect from the splitter to the subwoofer:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
If you need different lengths or prefer the premium cable options (not usually necessary and some are heavy and stiff), then you can find them here:
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10218
That was my first thought (or he could run them from the speakers to the sub--same thing), using the speaker-level or "HI-LEVEL" inputs, but on second thought with the 3.5mm-to-RCA connection he could use the crossover control, which may or may not (usually not, on most subs) be active with the speaker-level inputs.
Robert Cook is offline
Old 03-07-2013, 01:46 PM
cel4145's Avatar
Liked: 2134
I'd always wondered about this. Depending on the impedance of that connection, is it effectively acting like running sub in series with the speakers?
Old 03-07-2013, 01:53 PM
Quoted: 34 Post(s)
Liked: 55
If the subwoofer is properly designed, then the impedance of its speaker-level input should be very high, like in the thousands of ohms--all it's doing is sensing the voltage of the signal, not drawing a significant amount of power.
It should be connected in parallel with the speakers, not in series.
Old 03-07-2013, 01:55 PM
cel4145's Avatar
Liked: 2134
Old 03-07-2013, 05:14 PM - Thread Starter
IJ300's Avatar
Thanks, I really appreciate all the help.
IJ300 is offline
Old 03-07-2013, 08:47 PM
Quoted: 34 Post(s)
Liked: 55
Oh, and by the way, although this is moot now, for those who may be curious I just measured the DC resistance (close enough for inputs) of my subwoofer's speaker-level input (while it was off) at 500 ohms--that's less than I was thinking, having other types of inputs in mind, but it's reasonably high. This may be higher or somewhat lower on other subs, but unless the designer is a dummy, it shouldn't be excessively low. 500 ohms means that with 6 ohm speakers, for example, the total "nominal" impedance will be about (6 * 500) / (6 + 500) ~= 5.9 ohms (a gross oversimplification, but sufficiently illustrative), which is hardly devastating for most decent amplifiers.
Old 03-07-2013, 08:58 PM
cel4145's Avatar
Liked: 2134
Thanks again, Robert. That's really good to hear. I've got an old HK AVR 35 that everything connected with DSP functionality is burned out. No sub out. Even the headphone jack. Only thing working is the main direct out to the left/right channels, which makes it fine for stereo usage. Was thinking I need a sub with speaker level line in and line out to run with it, but I guess not smile.gif
Old 03-10-2013, 12:37 AM
HillaryClinton's Avatar
This setup for the lepai....can it work for the Marantz SR-8000? It technically has a sub out but it deactivates once you leave source direct mode(rendering the music quality pretty bad when compared). I would love the sub to work with music when in source direct mode but have not found a solution thus far. I have the exact same speakers and sub as the original poster, I was almost going to buy the same amp but was told the Marantz was way better sound wise for music which I am sure is true given its retail price when it came out but the lack of sub is ruining the experience.
I don't mind controlling he crossover and volume from the back of the sub I just want the sound quality of the source direct with the lows that the sub gives me. Any help would be greatly appreciated, I have been goin a bit Crazy trying to find a solution and would hate to get rid of the Marantz since I payed 60 bucks for it and lugged it back to my house which was a days workout given its weight and how long I was walking with it :-\.
Edit: Figured it out, just needed a 3.5 splitter and 2 RCA to 3.5 cords, works now, just need to control the woofer from the back. Thanks though Robert, figured it out based on your suggestions for the Lepai.
HillaryClinton is offline
