The relation between OHMS & bass ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-08-2013, 05:51 AM - Thread Starter
ZozoA320's Avatar
Hi friends:
There is a relation between the the ohms and bass.
Because i read someone hear the klipsch RF 7 II & the jbl tl 260.
And he said the klipsch bass not performe like jbl tl 260 because the jbl is 8 ohms but klipsch is 8 ohms compatible.
So what the relation between the ohms and bass...?
ZozoA320 is offline
post #2 of 9 Old 03-08-2013, 07:04 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
None. Ohms is your speakers impedance. A 4 ohm speaker is harder to drive than a eight ohm speaker. If your amp is four ohm stable, then you'll get more power from it in a four ohm speaker and it will get louder than an eight ohm speaker assuming the two speakers have the same efficiency. Efficiency is how loud a speaker gets with one watt of power applied to it. If a speaker is 88 dB/watt, then it will put out 88 dB's of loudness when you put one watt into it. If a speaker is 93 dB/watt, then it will put out 93 dB when one watt of power is put into it.
The amount of bass a speaker puts out is more dependent on driver size, cabinet design, and crossover design. Not to mention room interaction being probably the number one factor of how a speaker sounds in any given room.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #3 of 9 Old 03-08-2013, 07:22 AM
Bill Fitzmaurice's Avatar
Liked: 4653
There is none.
Bill Fitzmaurice is online now
post #4 of 9 Old 03-08-2013, 09:02 AM - Thread Starter
ZozoA320's Avatar
ok thanks brother but small advice...
Klipsch says RF 7 II is 8 ohms compatible,,,so the output of my Amp should be ( 4 or 8 ohms .......) whats the best ohms to RF 7 II.
many thanks .........
smile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gif
ZozoA320 is offline
post #5 of 9 Old 03-08-2013, 11:35 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It doesn't matter. As long as your amp is stable to 8 ohms or lower you'll be fine.
post #6 of 9 Old 03-08-2013, 01:41 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Not sure either. Of course the jbl bass is going to sound different then the klipsh.
RicardoJoa is offline
post #7 of 9 Old 03-08-2013, 03:07 PM - Thread Starter
ZozoA320's Avatar
What that is meaning, can you explain that.
Which better in the bass.
ZozoA320 is offline
post #8 of 9 Old 03-08-2013, 03:21 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
I dont know, klipsch and jbl are two different brand so i dont think why should they sound the same. Of course they dont.
post #9 of 9 Old 03-26-2013, 08:20 PM - Thread Starter
ZozoA320's Avatar
Thanks alot
ZozoA320 is offline
Reply Speakers
