speaker size constraints - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-08-2013, 02:24 PM - Thread Starter
kcmoney13's Avatar
Hey all,
I have been doing a lot of research on here and was looking for some feedback.
I have just recently built a built in surround for my tv. the issue is that I only have about 3.5 inches of height where i can put LCR speakers under. I am running a receiver and a sub already plus the house that we bought already has speakers in the ceiling for the rears.
I was just curious what you all would suggest for a smaller compact speaker for the fronts. I only have about 45" of space to separate them so there isn't a whole lot of room. I am not trying to break the bank but would love to have something that sounds nice.
Your opinions are always valued.
Thanks so much
Kris
kcmoney13 is offline
post #2 of 4 Old 03-08-2013, 02:46 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Find a way to make a bigger opening or look for another spot to place speakers as I could not fond anything.
Smallest I found was 3.9 inches.
http://www.jblpro.com/catalog/general/Product.aspx?PId=416&MId=2
ifor is offline
post #3 of 4 Old 03-08-2013, 03:32 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
If you could possibly accommodate larger speakers, then do so by all means. If not, then check out the Cambridge Audio Minx:
http://www.cambridgeaudio.com/pages/minx-speaker-systems
http://www.avsforum.com/t/1339511/cambridge-audio-minx-loudspeaker-discussion-thread/0_100
There are always major tradeoffs involved with using speakers this small, but these are probably among the best teeny-tiny, itsy-bitsy wittle baby speakers. wink.gif
Robert Cook is offline
post #4 of 4 Old 03-09-2013, 07:26 AM - Thread Starter
kcmoney13's Avatar
Hey Guys,
Thanks so much for your reply I will definitely check those out. Unfortunately I only have a small area.
Thanks again
Kris
Reply Speakers
