B & W - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-09-2013, 03:57 AM - Thread Starter
londrie's Avatar
Anyone has advice on the B & W CM9 standing speakers.
It may a good choice for me ?
londrie is offline
post #2 of 9 Old 03-09-2013, 06:03 AM
Paraneer's Avatar
Liked: 47
Londrie, you have now started ten different threads about what we think of different brands of speakers. Why is this important to you? What you think is far more important. Your the one who will have to pay for them and hear them. This shotgun approach of yours will get you nowhere and as you can see, very little response from Forum members - I think were all wise to you now.
So I will repeat what I said in another one of your threads before I learned to recognize your name. Start educating yourself! If you don't know anything about audio or HT, thats OK - we all have to start somewhere. Your off to a good start already as you are smart to inquire about speakers - the components that you actually can hear and will make the most the impact. Keep pursuing this but get to a store and listen!!! Here are some pointers...
1. Are you in or near a major city? If so, at the very least find a Best Buy with a Magnolia in it. You can audition at least 3 of the brands your referring to. Also, if you have them, find some smaller independent HI FI shops to hear other brands.
2. What do want in a speaker? There is no perfect one. They are all a compromise. Also, don't confuse LOUD with good sound. The loudest is usually not the purest or most true to the source material. Some that are LOUD can also be quite obnoxious.
3. Bring music and a movie that you know very well for your auditions. Don't let the delaer select what is to be played - you bring it with you.
4. Have the dealer drive the speakers using electronics that are most close to what you have at home. If you don't have electronics, and hopefully you don't, just audition the speakers and find the ones that sound best to you. You can then worry about getting the right amp for them later.
5. Speakers use different types and materials for their drivers, especially for high frequency drivers. Some use domes made from soft fabric or harder metal, some use horns, some use ribbons, etc. Each type of driver has a unique sound and one may sound harsh to you while the other just right. You have to find out for yourself. We cannot tell you this.
If you follow the above, you'll be on your way to making a far more intelligent choice to get what is right for you. If you don't want to follow the above and insist on asking us what is best, then I will tell you.
Get what I have, Vienna Acoustics Bach Grands, as they are the best speakers in the world!!!
Marantz PM15S2 LE, Arcam FMJ CD-17, VPI Traveler V2 with an Ortofon Rondo Blue, Technics SL-1400 with an Audio Technica AT-14sa, Simaudio Moon 110LP, Pro-ject Phono Box S, Pioneer Elite VSX-52, Pioneer Elite BDP-52FD, Dynaudio Focus 260's, Vienna Acoustics Theatro Grand, Wharfedale Diamond 9.2s, REL T-1 & Panasonic TC-P54S1
Paraneer is offline
post #3 of 9 Old 03-09-2013, 07:40 AM
Bill Fitzmaurice's Avatar
Liked: 3769
Go listen to some.
Bill Fitzmaurice is online now
post #4 of 9 Old 03-09-2013, 07:56 AM
inthecup's Avatar
I recently decided to ungrade and thought my 2 main speakers would be a nice place .. I have a budget of $3000 .... B & W CM9 @ $1500 each fits in well .. I presently run a Rotel 1550 reciever ... svs sub .... rega TT ... and B & W 604s ... front speakers .... Just started to get the upgrade itch and have spend about $6000 for my presant system and thought the extra $3000 would be a nice upgrade ... not sure where the $$$ would be best spent but the 2 CM9's sure stick out !!!!!
inthecup is offline
post #5 of 9 Old 03-09-2013, 08:15 AM
Class A's Avatar
Quoted: 239 Post(s)
Liked: 219
I agree go out and audition. Our opinions are really subjective. What I like you may not like. Your own ears will tell you what is right for you. Part of the fun is the hunt.smile.gif
Class A is offline
post #6 of 9 Old 03-09-2013, 08:19 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1234
They have a good reputation for good sound quality at a price.
You can go out and listen to them if you want to, but please be aware that the demo room's acoustics have a profound effect on how they sound. The chances that they will sound anything like the show room demo at home is slight.
arnyk is offline
post #7 of 9 Old 03-09-2013, 11:43 AM
postrokfan's Avatar
Quoted: 439 Post(s)
Liked: 2452
Agree with the others. Audition and feel free to check out the B&W owners thread.
HT/Living room: FR/FL Sierra 1 NrT, Sierra-1 NrT Center, B&W ASW610, Yamaha RX-A2030, Oppo BDP-93, ATV.
2-channel: B&W 804D, B&W ASW608, Parasound P5, Parasound A23, Marantz CD5004, Rega RP1, Bluesound Node2.
postrokfan is offline
post #8 of 9 Old 03-10-2013, 06:09 PM
ThumbtackJack's Avatar
Quoted: 21 Post(s)
I've read that the CM9s have poor measurements which is funny since I hear that B&W, in general, are very accurate speakers.
ThumbtackJack is offline
post #9 of 9 Old 03-10-2013, 06:22 PM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
In terms of on-axis and horizontal off-axis FR, B&W (even the $25,000 800D2 and $14,000 802D2) don't have the best measurements. For example, the $300/pr Infinity P363 have better on-axis and off-axis than any B&W speakers (including 800D2 & 802D2). Of course, the 800 & 802's spectral decay/ cabinet resonant measurements are as good as it gets.
Their on-axis/ off-axis FR don't measure as "poorly" as Wilson Audio, Acoustic Vienna, Magnepan, MartinLogan, Klipsch, etc, either.
For example, the 802D2 is +/-2.9dB, 800D2 is +/-5dB, but Wilson and Vienna are like +/-8dB to +/-10dB.
But measurements are not everything. Many people love the sound of Seaton, JTR, Tekton, etc, and none of these speakers even have any measurements at all.
So like everyone here is saying, just go audition some B&W speakers and see for yourself. Take all opinions with a grain of salt.
AcuDefTechGuy is offline
Reply Speakers
