Energy C-Series: Which for surrounds? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-10-2013, 02:23 PM - Thread Starter
cesjr02's Avatar
Hello everyone. I'm slowly building a home theater. I found a great deal on a pair of Energy C-200's so I started with those. I use the C200's as my mains, C-C100 for the center and a 10inch down firing sub. I have everything paired with a Denon AVR. The final piece of the puzzle is to decide what I'm going to do with the surrounds.
The two options I'm considering: Retain the C200's for the front speakers and find some C100's or C50's to use as surrounds. Or a slightly pricier option, replace the fronts with C300 or C500 towers and use the C200's for the surrounds. My only concern is the C200's being overkill for surrounds as they are pretty large and hefty bookshelf speakers. Also how much benefit would I hear using Energy tower speakers as the mains?
Any thoughts or opinions would be greatly appreciated.
cesjr02 is offline
post #2 of 9 Old 03-10-2013, 02:40 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15621
fwiw ,you dont need same brand speakers for surrounds just the front lcr are recommended for the same timbre for smooth soundstage across the front.you pretty much could use any set of speakers for surrounds.
i'm so laid back,i'm laid out
smasher50 is offline
post #3 of 9 Old 03-10-2013, 04:34 PM - Thread Starter
cesjr02's Avatar
Thanks for the reply. I'd prefer to stick with Energy C-series for the reason of cosmetically matching the other speakers.
cesjr02 is offline
post #4 of 9 Old 03-10-2013, 04:49 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
you may not need the same brand for surrounds but if you can, why not do it?
cesjr02 likes this.
Afro GT
afrogt is offline
post #5 of 9 Old 03-10-2013, 05:01 PM
losservatore's Avatar
Quoted: 2300 Post(s)
Liked: 2047
instead of hunting for this speakers why no go with a Jamo setup, they have the 5.0 pretty cheap and is a tower package.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #6 of 9 Old 03-10-2013, 05:10 PM - Thread Starter
cesjr02's Avatar
Jamo makes nice speakers for sure. But why sell the speakers I have and start over?
cesjr02 is offline
post #7 of 9 Old 03-10-2013, 05:20 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15621
in that case the 50's would be fine. if you listen to alot of sacd or other 5.1 music might opt for the 100's then
cesjr02 likes this.
post #8 of 9 Old 03-10-2013, 05:25 PM
Liked: 2047
Where did you get all those speaker options also if you have those options what are the price for those speakers.
post #9 of 9 Old 03-10-2013, 06:31 PM - Thread Starter
cesjr02's Avatar
Thanks, the 100's would be easier to wall mount vs the super heavy 200's.
I've purchased all second hand, (Ebay, local pawn store.) I'm not in any immediate hurry so waiting for a great deal on used speakers is not an issue. Price varies.
cesjr02 is offline
Reply Speakers
