Outdoor Speaker Wire - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-10-2013, 05:58 PM - Thread Starter
horsegoer's Avatar
I bought this and ran it a few years ago for my deck speakers. It works fine but we are renovating and I was going to buy and run new landscape wire( the run is outdoors under my deck. Now that I am looking at it it might actually be landscape wire I bought and ran the first time. Anyway to tell? Thanks. photo(11).JPG 120k .JPG file photo(12).JPG 132k .JPG file
ID:	67799   Click image for larger version
beau
horsegoer is offline
post #2 of 7 Old 03-10-2013, 08:24 PM
Bill Fitzmaurice's Avatar
Liked: 4630
Only if there's a label embossed in the jacket. But so long as the gauge is adequate it doesn't matter, especially as you know it will hold up.
Bill Fitzmaurice is online now
post #3 of 7 Old 03-16-2013, 09:59 AM - Thread Starter
horsegoer's Avatar
I just looked at it and it is stamped 16/2 SPT-2. Is this okay for outdoor? Also, on run to my speaker is 25' and the other is 40'. Is 16/2 not the right gauge? Thanks.
beau
post #4 of 7 Old 03-16-2013, 10:09 AM
Liked: 4630
You can use this to find if the gauge is sufficient:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
post #5 of 7 Old 03-16-2013, 10:29 AM - Thread Starter
horsegoer's Avatar
Thanks..seems like 16 gauge is okay. Is the SPT-2 okay for outdoor? it is covered most of the way under my siding?
beau
post #6 of 7 Old 03-16-2013, 11:29 AM
Liked: 4630
SPT-2 indicates a medium thickness insulation. It doesn't mean that it's UV resistant, which is the main reason for outdoor wire insulation cracking, so keep it out of direct sunlight as best as you can.
post #7 of 7 Old 03-16-2013, 03:42 PM - Thread Starter
horsegoer's Avatar
beau
Reply Speakers
