Recommend a pair of ~100 watt 2 channel speakers for music... - AVS Forum | Home Theater Discussions And Reviews
Old 03-10-2013, 08:11 PM - Thread Starter
MLJones's Avatar
Hi all,
Due to the available resources on this website I've been able to begin upgrading my home audio system. The living or main audio space has been blessed with a 2.1 system that will see a 5.1 in the future.
However this space is not the area I'm looking for guidance... I'm utilizing a Denon 1913 AVR and I want to begin taking advantage of the second zone's capabilities. The second zone will be in the basement and these speakers will be utilized for music during pool / card games. These speakers are limited to the power of the AVR... 125 watt RMS - 185 watt max. I'm looking for recommendations for a set of floor standing / book shelves or even speakers in general for a DIY box.
The budget is low i.e. $200 range and any additional equipment is kind of out the question (i.e. another receiver, amp, or powered sub). I'm thinking a low end set of Sony SS-F6000's may be a viable option, but if any experienced audiophiles have some better ideas then I'd be interested in hearing them.
MLJones is offline
Old 03-10-2013, 08:22 PM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
A set of the def tech sm350/450 can be had for ~300 dollars from new egg! A good speaker which will get loud and has good bass!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
Old 03-10-2013, 08:41 PM
Resonate's Avatar
Cambridge Audio S30 Bookshelves seem like a perfect fit based on your description. $219/pair and supposedly still available here: http://www.avhifi.com/shop/cambridge-audio-s30-speakers-oak-p4.html
You'd probably want some stands though.
reviews:
http://www.whathifi.com/Review/Cambridge-Audio-S30/
http://www.avsforum.com/t/1327952/almost-got-floored-by-cambridge-s30
EDIT:I haven't heard the Studiomonitors, and on paper they get louder, but the venerable zieglj01 seems to prefer the S30 over either, fwiw: http://www.avsforum.com/t/1327952/almost-got-floored-by-cambridge-s30/300#post_22927838
Resonate is offline
Old 03-10-2013, 08:43 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you don't care about color look at the Boston A250 towers for $99 each. They're white with black grilles.
http://www.accessories4less.com/make-a-store/item/BOSA250WHA/BOSTON-ACOUSTICS-A250-2-Way-Dual-5.25in-Floor-Standing-Speaker-EA-White/1.html
If you can spend a little more the Infinity P363 towers are $117 each if you need black.
http://www.frys.com/product/6878376?site=sa:adpages page:P37_SUN date:031013
Also Pioneer FS52 which come on sale for $99 quite often
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Home+Theater+Speakers/SP-FS52
If you want bookshelf speakers look at the Boston A25, Infinity P163 or Cambridge S30.
http://www.accessories4less.com/make-a-store/item/BOSA25GB/BOSTON-ACOUSTICS-A25-2-Way-5.25in-Bookshelf-Speaker-Each-Gloss-Black/1.html
http://www.audioadvisor.com/prodinfo.asp?number=CAS30%20%20%20%20%20BLK
oh yeah and maybe the HTD Level TWO bookshelf
http://www.htd.com/Products/level-two-speakers/Level-TWO-Bookshelf-Speakers
Afro GT
afrogt is offline
Old 03-10-2013, 09:31 PM - Thread Starter
MLJones's Avatar
Personally I'm leaning toward floor standing speakers due to an external sub being out of the question. However, of the recommendations thus far maybe I should consider the def tech 350s and read up on those Cambridge bookshelves.
The white Boston towers are the right price but as most would agree... I'm not sure a bright white speaker is the fit for the man cave.
I have considered the pioneer fs52s... So I think I'll compare those to the infinity towers.
The other bookshelves... I think I've ruled out, again bc a stand alone sub is not in the plan.
Thanks for the input all!!
MLJones is offline
