no clue on 1st HT build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-11-2013, 09:16 PM - Thread Starter
KoolDad's Avatar
Hello All,
My HT is located in the basement of my home. The room has no windows and has controlled lighting so that I can make it completely dark. The current entrance calls for french doors, however I am thinking of going with hidden hinges and a pocket door. I would like some advice on speaker suggestion and room layout please? The room measures 16'W x 30'L and has 9' ceilings. I would like to have platforms in this room too. Behind the sheet rock of three of the walls is concrete, the 1 remaining wall shares to the rec room. I have insulated that wall and hung dB-3 for soundproofing. I have prewired the room for a 7.2 surround. Here is a list of a few things that I would like to use:
120" projector screen
Oppo 103 blu ray
Pioneer Elite SC-68
Thanks!!
KoolDad is offline
post #2 of 6 Old 03-12-2013, 12:44 AM
Nethawk's Avatar
Liked: 119
Wow. You're more prepared than most :-)
People will be asking you what your budget is for sound system - AVR (or separates), speakers and sub(s). This is just a baseline, 'cause most of the recommendations will come in over budget :-D
One additional necessary data point - approximate time spent in movies/music/gaming.
Good luck with your setup, you're going to have lots of fun!
Nethawk is offline
post #3 of 6 Old 03-12-2013, 01:36 AM
kemetblk's Avatar
Quoted: 16 Post(s)
Budget? speaker size (tower, sat, etc.)? Basically, what Nethawk said.
AVR: Denon X3300
F/C/R: Polk RTi A9's / CSi A6 / Speakercraft AIMWIDE 3 / Sub: SVS PB12-NSD
Sony XBR-75X940D, Toshiba HD-A30, Nvidia Shield TV (2015), Xbox One S, PS3
PC: Core i7, 16GB RAM, 512GB ssd + 4TB hdd, GTX 970 SSC
kemetblk is offline
post #4 of 6 Old 03-12-2013, 07:24 AM - Thread Starter
KoolDad's Avatar
I will use the room 65-70% movies and 20-25% sports (football&basketball), while the rest goes to gaming. I have ran an HDMI and 2 Cat5E cables to where projector is going. My tv viewing is Direct TV with HD connection. Speaker wise, I don't think that I will be using towers and traditional center for front. It was suggested to me to use 3 B&W Cinema ST8.4 LCRS for front, however that will be out of my budget.
KoolDad is offline
post #5 of 6 Old 03-12-2013, 10:18 AM
Robert Cook's Avatar
Quoted: 37 Post(s)
Liked: 58
But what IS your budget for the speakers and subwoofer(s)?
Robert Cook is offline
post #6 of 6 Old 03-12-2013, 10:30 AM - Thread Starter
KoolDad's Avatar
My budget would $5K including subwoofer.
KoolDad is offline
Reply Speakers
