Speaker selection/size - AVS Forum | Home Theater Discussions And Reviews
Old 03-12-2013, 04:32 PM - Thread Starter
horsegoer's Avatar
Just finished running my speaker wires and cat 6 and in the process of closing the walls. Looking for fronts(either bookshelf or towers) a center and a possibly a sub. Will choose my rears later.I have a Polk psw10 that I used with my monitor 50 fronts( don't have anymore) but I'm not sure if I should keep it or get a better sub. My room is approximately 25'x30 and we listen to music and movies equally. What wattage speaker would suffice? I don't need the music blasting but once Ina while might want to crank it a little. Thanks,
beau
horsegoer is offline
Old 03-12-2013, 07:31 PM - Thread Starter
horsegoer's Avatar
Anyone .
beau
Old 03-12-2013, 07:36 PM
Elihawk's Avatar
Quoted: 1018 Post(s)
Liked: 868
Well, speakers can cost anywhere from a few hundred dollars to a few hundred thousand dollars, so a budget is a MUST before anyone can give advice...
Almost certainly, that sub will NOT do well in a room that size!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
Old 03-12-2013, 07:37 PM
g_bartman's Avatar
Quoted: 143 Post(s)
Liked: 122
You would get responses if you gave a budget and the receiver you will be using.
g_bartman is offline
Old 03-12-2013, 07:52 PM - Thread Starter
horsegoer's Avatar
I asked about the receiver on the other forum here and they suggested picking speakers first.my budget for fronts and center is about $600-700
beau
Old 03-12-2013, 10:52 PM
swallan's Avatar
Liked: 27
if you can find some def tech 350s or 450s and a clr2002 or clr2000 center they will sound real good for the price. i have the sm 350s and the clr2002 center and they sound great.
swallan is offline
Old 03-12-2013, 11:29 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
NewEgg has a real good deal on the sm450s, and Amazon has the clr2002 discounted.
For other options in that budget, Frys has regular discounts on the Infinity Primus and JBL ES series. However, I would pick the DefTechs over those.
David
crussader is offline
Old 03-13-2013, 03:54 AM - Thread Starter
horsegoer's Avatar
Thanks... How about in towers
beau
Old 03-13-2013, 04:13 AM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
Keep the Polk sub and get another one. Youre going to need 2 subs in a room that big. Your budget is unrealistic if you want any kind of quality sound in a room that big. Get towers and then save up and get a center. Then another sub. Then surrounds.
Licence to Kill
Bond 007 is offline
Old 03-13-2013, 08:16 AM - Thread Starter
horsegoer's Avatar
The size I listed is actually the kitchen, living room and dining room but it's pretty much open to one another so it's almost like one big room
beau
Old 03-13-2013, 08:30 AM
velocci's Avatar
Quoted: 117 Post(s)
i went to def tech's site and I can't find these 350s, 450s or clr2002/2000. can you give me links?
www.johnvelocci.com
system: Onkyo TX-NR 646 AVR with Polk Audio RtiA3 fronts and
BIC America F12 sub
velocci is offline
Old 03-13-2013, 08:55 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Old 03-13-2013, 08:59 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Infinity Primus 363 - (Frys.com)
JBL ES80 - (Frys.com)
Pioneer SP-FS52-LR
Here's a deal if you don't mind white:
http://www.accessories4less.com/make-a-store/item/BOSA250WHA/BOSTON-ACOUSTICS-A250-2-Way-Dual-5.25in-Floor-Standing-Speaker-EA-White/1.html
David
Old 03-13-2013, 10:46 AM
velocci's Avatar
Quoted: 117 Post(s)
I can't find any of these on definitive technology's site. are these older models?
www.johnvelocci.com
BIC America F12 sub
velocci is offline
Old 03-13-2013, 11:19 AM
Elihawk's Avatar
Liked: 868
The sm350/450 have recently been discountinued...so they are not available from def tech. New egg/ amazon still has a limited stock.
Elihawk is offline
Old 03-13-2013, 11:22 AM
velocci's Avatar
Quoted: 117 Post(s)
have they been replaced with something else?
www.johnvelocci.com
BIC America F12 sub
velocci is offline
Old 03-13-2013, 11:38 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
These are sold individually, not as pairs.
http://www.amazon.com/Definitive-Technology-SM55-Bookshelf-Speaker/dp/B005XXMN6I/ref=sr_1_29?s=electronics&ie=UTF8&qid=1363196167&sr=1-29&keywords=definitive+technology
David
Old 03-13-2013, 10:48 PM
swallan's Avatar
Liked: 27
the sm350s and the450s have been replaced by the sm45 the sm55 and the sm65 i still dont think you can go wrong with the older models the prices are real good at newegg.
swallan is offline
Old 03-14-2013, 02:56 AM
Bond 007's Avatar
Liked: 1911
Why would small expensive audiophile bookshelf speakers be suggested for a space that large? And for a person who has such a small budget and is interested in music and movies equally? Please explain the advantages of that over some good towers.
Licence to Kill
Bond 007 is offline
Old 03-14-2013, 03:35 AM
Bond 007's Avatar
Liked: 1911
This is a good deal and would do better filling that space imo
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290279
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290281
And will bring you in under budget. $580 If you dont like the cherry they also come in black. Or if you want to go ahead and spend the whole $700 you can get these and your 5.1 system will be complete.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290275
Licence to Kill
Bond 007 is offline
Old 03-14-2013, 03:54 AM - Thread Starter
horsegoer's Avatar
Thanks. I saw a post ab
out
I saw a post on here about how the 75&75T sounded almost exactly the same. Thanks. BTW are their any soundbars out there that come cost lose to sound/volume as say the Polks you linked to?
beau
Old 03-14-2013, 03:58 AM
Bond 007's Avatar
Liked: 1911
out
Not in this universe. See my edit with the surrounds also.
Licence to Kill
Bond 007 is offline
Old 03-14-2013, 08:00 AM
velocci's Avatar
Quoted: 117 Post(s)
these are big ass speakers. for only $450 a pair, do they actually sound good? why are they so cheap?
www.johnvelocci.com
BIC America F12 sub
velocci is offline
Old 03-14-2013, 10:05 AM
Bond 007's Avatar
Liked: 1911
Many people think they sound good. They are Polks. MSRP is $500. They are discontinued.
Licence to Kill
Bond 007 is offline
Old 03-14-2013, 10:06 AM - Thread Starter
horsegoer's Avatar
GoldenEar Technology SuperCinema 3D Array----I heard this soundbar is sounds great. I'm going to a dealer to listen to it. Really want to avoid the aesthetics of front towers or bookshelf if I can. I thought they were really the only way to go for good sound
beau
Old 03-14-2013, 10:20 AM
velocci's Avatar
Quoted: 117 Post(s)
have they been replaced with a newer model with the same price?
www.johnvelocci.com
BIC America F12 sub
velocci is offline
Old 03-14-2013, 10:47 AM
Louquid's Avatar
Liked: 38
I personally love the way bookshelf and tower speakers look. I'd only use a soundbar if all I planned to do was watch talkshows or infomercials. Other than dialogue, you won't get much usable sound out of a soundbar.
Louquid is offline
Old 03-14-2013, 11:16 AM
Bond 007's Avatar
Liked: 1911
If aesthetics is more important than the way they sound when picking out speakers what can you say. If he is willing to pay as much or more for far inferior sound then have at it. The people that make soundbars have to make a living too and they love people like that.
Licence to Kill
Bond 007 is offline
Old 03-14-2013, 12:34 PM - Thread Starter
horsegoer's Avatar
beau
Old 03-14-2013, 01:06 PM
Louquid's Avatar
Liked: 38
OP, if you don't want to actually see your speakers, have you thought of in-wall? You would get much better performance out of an in-wall system than a soundbar, without having it clutter your area or view.
Louquid is offline
