Best cleaning solution for speakers. Woofers,tweeters and midrange? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-14-2013, 05:40 PM - Thread Starter
MelonSplitter's Avatar
I need to do some spring cleaning on my speakers. I pulled off the front grills and noticed some major dust and very off colored, faded speakers. How do I restore them to "look" like new again?
MelonSplitter is offline
post #2 of 5 Old 03-14-2013, 07:19 PM - Thread Starter
Armor All or Simple green maybe?
post #3 of 5 Old 03-14-2013, 07:32 PM
gtpsuper24's Avatar
Liked: 99
Are they paper or a poly/plastic material? For rubber surrounds a basic car dash wipes would work. Use a can of air to blow out the dust from the spider and venting. For paper cone speakers use this stuff:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=340-513
MelonSplitter likes this.
gtpsuper24 is offline
post #4 of 5 Old 03-14-2013, 07:55 PM - Thread Starter
They are paper. Thanks. This seems to be just what I was looking for. Have you personally used this? just asking, it doesnt really matter because I will be ordering a bottle anyway.
post #5 of 5 Old 03-15-2013, 01:15 AM
maxcooper's Avatar
Quoted: 13 Post(s)
A vacuum with brush attachment is good for getting the dust off, without marking or damaging the cones or surrounds.
maxcooper is offline
Reply Speakers
