2.0 speakers for small TV? - AVS Forum
post #1 of 2 Old 03-15-2013, 05:16 PM - Thread Starter
knightsilver's Avatar
Ive been using my Logitech X-140's with my system(computer) and always been very happy with them, originally bought them for the external treble control.
http://www.logitech.com/en-us/product/x-140-speakers?crid=47
Im now looking for some cheap/decent 2.0 (or 2.1) speakers for a small TV, thats also has the treble control.
Ive thought about just getting another set of the X-140's with an RCA adapter, but was looking for something that would mount on the wall easier?
Dont need crazy, just the external treble control, and decent sound on low to medium volume settings.
Thx,
KS
knightsilver is offline
post #2 of 2 Old 03-16-2013, 09:16 AM
Robert Cook's Avatar
I doubt there are many "computer speakers" that were meant to be mounted on the wall, and while you could use a floating shelf to mount them, most these days would be directed upward, which is probably less than optimal.
What about using something like the following instead?
http://www.amazon.com/LP-2020A-Lepai-Tripath-Class-T-Amplifier/dp/B0049P6OTI
Add a pair of any speakers of your choice. How much would you be willing to spend? You said "cheap" so maybe something like the following (mounts on the wall with a single screw):
http://www.amazon.com/BIC-AMERICA-DV-32B-Shielded-Speakers/dp/B00006JPDF
http://www.amazon.com/BIC-AMERICA-DV-32W-Shielded-Speakers/dp/B00006JPDE
You could also use bigger and better speakers that have more bass, but they'll cost more.
Robert Cook is offline
Reply Speakers
User Tag List
