is 60 ft too long for a 16 gauge wire? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-18-2013, 12:57 PM - Thread Starter
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
I have my speakers comming and I have to get some wire now. Because one of the speakers I have to do an extended run all alond the back of the house to reach it, so its well beyond the 48 feet they say for 16 awg wire. So do I have to get 14 and spend he extra money? dont know if it matters but I am running all tower speakers except for my center in a 7 channel set up. And my reciever is a pioneer sc-65. Thanks in advance for the help.
metalguy is offline
post #2 of 12 Old 03-18-2013, 01:03 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
buy at least 100 feet.
caloyzki is offline
post #3 of 12 Old 03-18-2013, 01:05 PM - Thread Starter
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
Well yes I would be buying in that length, but my question is about the guage of wire to use, for a distance over 48 feet, the reading i have seen says to do 14 awg not 16. But I dont want to waste money either. I am not running a 10k set up here.
metalguy is offline
post #4 of 12 Old 03-18-2013, 01:08 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
14 will be fine. but mostly use for 16 awg
caloyzki is offline
post #5 of 12 Old 03-18-2013, 01:16 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
Recommendations seem to be all over the place. Here's one article I found on the subject:
http://www.audioholics.com/education/cables/speaker-cable-gauge
Here's another I've seen referenced here several times:
http://www.roger-russell.com/wire/wire.htm
Saturn94 is offline
post #6 of 12 Old 03-18-2013, 01:18 PM
Nethawk's Avatar
Liked: 118
IMO you should bump it up to 12 AWG. It depends on a couple of factors - the ohm rating of the speakers and how much power you plan to run to them, but for that distance 12ga is the best choice to future-proof the cable runs. Check out this link for a table that can help with distances.
Monoprice 12AWG is good, and not expensive.
Nethawk is offline
post #7 of 12 Old 03-18-2013, 01:23 PM
Nethawk's Avatar
Liked: 118
Hey there Saturn!
Yeah, recommendations are different wherever you go. I've stuck with Roger Russell's rant table as a guide. Using this calculator the audible loss for a 120ft run of 12awg is acceptable.
Nethawk is offline
post #8 of 12 Old 03-18-2013, 01:39 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
Originally Posted by Nethawk View Post
Hey there Saturn!
Hey Nethawk!
Hope you're enjoying that great system despite that nonsense going on in the Salk thread! biggrin.gif
Saturn94 is offline
post #9 of 12 Old 03-18-2013, 01:51 PM
Nethawk's Avatar
Liked: 118
Hmm, will have to check this out! I haven't visited Salk thread in a long time.
Nethawk is offline
post #10 of 12 Old 03-18-2013, 01:59 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
Your system was used as an example there (unfortunately not a good one by a particular poster).....check it out.
Nethawk likes this.
Saturn94 is offline
post #11 of 12 Old 03-18-2013, 02:44 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
14ga doesn't cost that much if you buy from monoprice.com
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2791&seq=1&format=2
Afro GT
afrogt is online now
post #12 of 12 Old 03-18-2013, 02:56 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
Saturn94 is offline
Reply Speakers
