Speaker stands for KEF Q300 and Q100 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 03-18-2013, 06:24 PM - Thread Starter
prateek33's Avatar
Please recommend the best stands for Q300 as fronts (probably at 30 inch) and Q100 as rears (~30-36 inch)
I googled for images but then realized that the stands also affect the sound quality.
Junkyard:
Yamaha RX V673
HSU VTF3-MK4
KEF Q300, Q100, Q600
Panasonic 60ST60
Sony VAIO - XBMC
XBOX 360
prateek33 is offline
post #2 of 18 Old 03-18-2013, 08:00 PM
unbridled_id's Avatar
unbridled_id is offline
post #3 of 18 Old 03-18-2013, 08:29 PM - Thread Starter
prateek33's Avatar
From reviews I see that these are not stable on carpet and are not wide at base.
Junkyard:
Yamaha RX V673
HSU VTF3-MK4
Panasonic 60ST60
Sony VAIO - XBMC
XBOX 360
post #4 of 18 Old 03-19-2013, 04:49 AM
Quoted: 992 Post(s)
Liked: 520
I have Q100s on VTI DF36 stands. They're stable, especially after I filled the post with kitty litter. When I looked, they were one of the few options that tall with wire management.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #5 of 18 Old 03-19-2013, 07:54 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
You want stands that are as rigid and massive as possible.
All-welded steel construction is usually best, and filling the vertical column with steel birdshot or sand is a very good idea to add mass and damping.
You can get a metal shop to make good stands from a 3-inch diameter steel tube and metal plates welded to top and bottom. You can save a lot of money that way and get very good stands.
You can get the floor spikes from many vendors including Music Direct or Amazon.
commsysman is online now
post #6 of 18 Old 03-19-2013, 10:24 AM
stickx's Avatar
Only $119 for 8 at MD. You might as well buy pre-made stands for that price.
stickx is offline
post #7 of 18 Old 03-21-2013, 11:04 AM - Thread Starter
prateek33's Avatar
any other advices? How are Sanus Stands? I am looking at the wood ones. Plate size around 7x7. While speakers are 14x8
Is it good?
Junkyard:
Yamaha RX V673
HSU VTF3-MK4
Panasonic 60ST60
Sony VAIO - XBMC
XBOX 360
post #8 of 18 Old 03-21-2013, 11:10 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
I JUST bought this yesterday at my local guitar center store! and yes it is better what i bought from best buy sanus, i returned the sanus and get this instead. DR Pro Maple Wood Studio Monitor Stand
caloyzki is offline
post #9 of 18 Old 03-21-2013, 11:27 AM - Thread Starter
prateek33's Avatar
They are 36" tall. Need 30"
Junkyard:
Yamaha RX V673
HSU VTF3-MK4
Panasonic 60ST60
Sony VAIO - XBMC
XBOX 360
post #10 of 18 Old 03-21-2013, 11:31 AM
Louquid's Avatar
Liked: 38
You want your stands to be 30" tall or the speakers on top of the stands to be 30"?
Also guys, how well does kitty litter work as mass loading?
Louquid is offline
post #11 of 18 Old 03-21-2013, 11:33 AM - Thread Starter
prateek33's Avatar
Kitty litter works as good as sand or shots.
Junkyard:
Yamaha RX V673
HSU VTF3-MK4
Panasonic 60ST60
Sony VAIO - XBMC
XBOX 360
post #12 of 18 Old 03-21-2013, 01:59 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
And can act as a room freshener....
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #13 of 18 Old 03-21-2013, 09:48 PM - Thread Starter
prateek33's Avatar
Any suggestions guys? Sanus 30 seems to be the best choice till now
Junkyard:
Yamaha RX V673
HSU VTF3-MK4
Panasonic 60ST60
Sony VAIO - XBMC
XBOX 360
post #14 of 18 Old 03-22-2013, 11:19 PM
sdg4vfx's Avatar
Quoted: 110 Post(s)
Liked: 151
I've been using these ...
http://www.amazon.com/Vantage-Point-SSB-30BB-Adjustable-Bookshelf/dp/B0006G1IJ0/ref=sr_1_7?ie=UTF8&qid=1364019290&sr=8-7&keywords=adjustable+speaker+stands
I wanted stands with adjustable height. They are very stable. I wasn't crazy about the look, but now that I have them in the room they look/work fine. Some of the more curved aspects of the design disappear into the room. Basically you don't notice them, which works for me.
sdg4vfx is offline
post #15 of 18 Old 03-22-2013, 11:45 PM - Thread Starter
prateek33's Avatar
I wanted stands with adjustable height. They are very stable. I wasn't crazy about the look, but that I have them in the room the look/work fine. Some the more curved aspects of the design disappear into the room. Basically you don't notice them, which works for me.
I thought I would have to screw in speakers to this? Will this be able to hold kef q300's?
Junkyard:
Yamaha RX V673
HSU VTF3-MK4
Panasonic 60ST60
Sony VAIO - XBMC
XBOX 360
post #16 of 18 Old 03-23-2013, 10:33 PM - Thread Starter
prateek33's Avatar
Finalized down to these two:
Please suggest which is better. Speaker is 14 inch in length. KEF's Q300 & Q100
Bell'O SP-300 30" (http://www.amazon.com/BellO-SP-300-Finish-Speaker-Stands/dp/B000M4MEXU/ref=cm_cr_pr_product_top)
VS
Vantage Point SSB-30BB (http://www.amazon.com/gp/product/B0006G1IJ0/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER)
Junkyard:
Yamaha RX V673
HSU VTF3-MK4
Panasonic 60ST60
Sony VAIO - XBMC
XBOX 360
post #17 of 18 Old 03-24-2013, 08:29 AM
txinliner's Avatar
ive got my q300s on some vti stands from speakerstands online filled them with sand and put them on 18 inch tile squares that match my carpet, secured with blu tack.
marantz sr 6005, marantz ,cd5003 yamaha,c6761sacd pioneer pls50 turntable w / sure m97 xe cart rotel rq 970bx phono amp audioquest type 4 speaker cables ,audioquest g snake interconnects kefq300 ,mains on 28 '' vti stands, mission center,and mission mi 730 surrounds. svs pb10 sub
txinliner is offline
post #18 of 18 Old 03-24-2013, 01:51 PM
sdg4vfx's Avatar
Quoted: 110 Post(s)
Liked: 151
You could use the provided screws, but I use blu-tac with no problems.
I've used the stands for both the Q100 and Q300 (the Q300 is only 1.2" wider and deeper than the Q100). FWIW, both speakers' weight-center is slightly towards the front so I always place the speakers on the stand accordingly - i.e. with the backside of the speaker sticking out a bit farther than the front side of the speaker. The extra inch of depth on the Q300 didn't matter.
sdg4vfx is offline
Reply Speakers
Kef Q300ch Bookshelf Speaker Pair Cherry , Kef Q300wa Bookshelf Speakers
