Speaker Upgrade - JTR vs KEF Reference vs Focal Electra - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 124 Old 04-26-2013, 08:17 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Originally Posted by AcuDefTechGuy View Post
Now you see, a 6ft Emotiva speaker cable costs $60 or $10/ft.
You can get Kimber Kable 4PR for $3/ft or 8PR for $5/ft bare wires and add banana plugs yourself.
24 banana connectors is $16: http://www.amazon.com/Connector-Banana-Plugs-Screw-Black/dp/B0093F4ROI/ref=sr_1_4?ie=UTF8&qid=1366983594&sr=8-4&keywords=Banana+plugs
Emotiva 2 6ft cables x $60 = $120
Emotiva 2 9ft cables x $70 = $140
Kimber 8PR 2 6ft cables x $30 = $60 + $16 (save the remaining bananas for later) = $76
Kimber 8PR 2 9ft cables x $45 = $90 + $16 = $106
I just wanted to show him an alternative with slightly better looking, but not yet obscenely priced cables (there are likely better examples, but it's not an area I've done a lot of searching in redface.gif).
rick240 is offline
post #92 of 124 Old 04-26-2013, 09:20 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Originally Posted by stormwind13 View Post
I wouldn't give someone too much flak for spending a few hundred bucks on cable. It's when I see someone buy a $5000 3 foot interconnect that I chuckle to myself and wonder if they could tell the difference in a blind test.
Still why spend even a couple hundred bucks? There will be no better performance from a $200 cable than a $10-15 50' roll of quality 12-14guage wire from Monoprice?
ack_bk is offline
post #93 of 124 Old 04-26-2013, 09:32 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Really. If you want to spend more money to get better sound buy better speakers.
If you've got money to burn on something that won't do anything to improve the sound of your system and care more about how your cables look than how they work then by all means waste it on pretty wire. And then turn in your Man Card. rolleyes.gif
Bill Fitzmaurice is offline
post #94 of 124 Old 04-26-2013, 10:57 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Some people waste money on sports (football, basketball, baseball, etc), alcohol, tobacco, fine dinning, gambling, fancy clothes & jewelry, cars, motorcycles, and other accessories and hobbies.
Some people waste their money on wires and amps. No big deal.
If if makes you happy (and it doesn't hurt anyone), it can't be that bad.
AcuDefTechGuy is offline
post #95 of 124 Old 04-26-2013, 11:00 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
I may not believe in wires & amps having sounds of their own.
But if a friend of mine believe in it, I will tell him that I don't believe in it. But if he still wants to believe it, there's no harm done either.
Audio is just one part of our senses, in addition to sight, touch, smell, taste.
But don't forget our emotions and mood and how they relate to our ENJOYMENT.
And that's what it's all about, right? Our ENJOYMENT?
If a friend has more enjoyment believing that his speaker cables improved the sound, who am I to deprive him of that harmless enjoyment? biggrin.gif
If it was one of mine friends I'd tell him to give his head a shake because fancy speakers wires are going to make his speakers sound better. But of course I don't really believe in sugar coating things for people to make them feel better about something that's total untrue.
jbrown15 is offline
post #96 of 124 Old 04-26-2013, 11:01 AM
jbrown15's Avatar
Liked: 1993
Wasting money is one thing, but believe something does something that it doesn't is a totally different matter.
jbrown15 is offline
post #97 of 124 Old 04-26-2013, 11:11 AM
Quoted: 175 Post(s)
Liked: 262
If your friend wants to spend $48 total on two 8ft Kimber Kable 4PR cables, would you preach to him about the evils of wires?
post #98 of 124 Old 04-26-2013, 11:18 AM - Thread Starter
pinoy ako's Avatar
Liked: 26
I've got a pretty decent offer from Dubai local AV Shop, 9 dollars per ft (with 4 banana connectors) Analysis Plus Oval 12/2. They are authorized seller and buying/selling in bulks. They do all the assembly, crimping etc. Much cheaper than Emotiva..biggrin.gif. I think this is fine and can be delivered to my doorstep biggrin.gif
Anthem Statements | Kef Reference 205/2 | Kef LS50 | PSA Triple XS30SE | Panasonic AE8000 | Dalite 110" PJ Screen | CAPS V3 Zuma | Synology DS1512+ (15TB) | Cambridge Azur 651BD
pinoy ako is offline
post #99 of 124 Old 04-26-2013, 11:24 AM
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1116
Well, I needed 500 feet of wire and they are all hidden, so I bought 3 different kinds of wire. Bluejeans 10 gauge in wall, monoprice 12 gauge in wall, and Axiom bulk 12 gauge. The axiom was $1 a foot, the BJC was $.57 and the monoprice was $.40-$.50(Can't remember). The difference in wire is flexibilty. The axiom cable was outstanding and very easy to bend, cut, and never prick your fingers as it was nice and soft for terminations. The BJC was the opposite, very stiff and always caused my fingers to bleed. The monoprice was in between. I have all 3 wired in my theater and the sound is all the same of course. I would buy based on how easy it is to install terminations. I don't like monoprice bananna plugs at all. The expensive monster and then cheaper acoustic reality work best so far. Axiom's banannas were bad as well. Bad meaning did not fit snug in my equipment. Maybe for different amps or something.
Marantz 7702 Atmos
MKtheater is online now
post #100 of 124 Old 04-26-2013, 11:24 AM - Thread Starter
pinoy ako's Avatar
Liked: 26
post #101 of 124 Old 04-26-2013, 11:26 AM
MKtheater's Avatar
Liked: 1116
Buy Axiom bulk cable for $1 a foot and then add the monster banannas at best buy for $20. Much cheaper and you get a good quality 12 gauge speaker wire. So a 10 foot cable would cost you $30.
Marantz 7702 Atmos
post #102 of 124 Old 04-26-2013, 11:27 AM
jbrown15's Avatar
Liked: 1993
Evil of wires? I already said the same thing to the OP, if you want fancy wires just to have fancy speaker wire by all means buy them. Just don't try selling me snake oil and giving me some horse cr@p story that they make your speakers sound better!
AcuDefTechGuy, the last part of my comment isn't directed at you either. I'm just saying in general.
jbrown15 is offline
post #103 of 124 Old 04-26-2013, 11:28 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Normal retail seems to more like twice that. Any reason for the ummm exceptional pricing?
http://www.spearitsound.com/Speaker_Cables-8_Kimber_4PR_Bare_Ends.html
http://www.needledoctor.com/Kimber-Kable-4PR-Speaker-Cable
http://www.thecableco.com/Product/4PR
3 times the wire for 1/3 the price: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2747
arnyk is offline
post #104 of 124 Old 04-26-2013, 11:35 AM
Liked: 4631
Originally Posted by pinoy ako View Post
When it's $42 more than was necessary that happiness could take the form of a bottle of 20 year old single malt with the money saved. cool.gif
The sixteen bucks I'd save not paying a Monster price is two six packs of micro-brew. Or four gallons of that which probably makes it possible for pinoy ako to consider Kimber Krap. biggrin.gif
post #105 of 124 Old 04-26-2013, 11:52 AM - Thread Starter
pinoy ako's Avatar
Liked: 26
I have extra $42 to buy a bottle of 20 year old single malt..we can share though tongue.gif
post #106 of 124 Old 04-26-2013, 12:01 PM
MKtheater's Avatar
Liked: 1116
Well, you can bare wire it for no money, but I change out things quite often and banannas are very quick to plug and unplug. Monster although more expensive fit better and don't fall out. Trust me, I tried cheaper ones and the best cheaper one so far are the AR's from best buy.
Marantz 7702 Atmos
post #107 of 124 Old 04-26-2013, 12:03 PM
Quoted: 175 Post(s)
Liked: 262
post #108 of 124 Old 04-26-2013, 12:06 PM
Quoted: 175 Post(s)
Liked: 262
I feel the same.
I have the money. I spend on higher quality connectors and cables that suit my desire.
post #109 of 124 Old 04-26-2013, 12:09 PM
Quoted: 175 Post(s)
Liked: 262
Well, you know some people are just too depressed to know what that means. biggrin.gif
post #110 of 124 Old 04-26-2013, 12:32 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I really like the Sewell banana plugs from Amazon.
ack_bk is offline
post #111 of 124 Old 04-26-2013, 01:49 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
Where are you getting 20yr old single malt for $42?
A fifth of Macallan 12yr costs me $57 here in Colorado which is better than the $95/fifth I was paying in Canada.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #112 of 124 Old 04-26-2013, 03:27 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Yes sir, I bought the Kef Ref 205/2 204/2 and LS50 as surrounds during GITEX in Dubai which gave me 40% discount plus Onkyo flagship PR SC5509 pre/pro free of charge. It is really a good bargain, that's why i couldn't resist..biggrin.gif
Congrats on all your new stuff. The wait is the hardest part. Tell us what you think when you get it hooked up and tuned.
Reefdvr27 is offline
post #113 of 124 Old 04-26-2013, 04:05 PM
Liked: 4631
New Hampshire. No income tax, no sales tax, and state run liquor stores with the cheapest prices around to draw in customers from all the surrounding states and Canada to buy their liquor here instead of at home, which is why we have no income tax and no sales tax. wink.gif
post #114 of 124 Old 04-26-2013, 04:37 PM
Quoted: 146 Post(s)
Liked: 246
Live free or die.
If New Hampshire had more business, I would have moved there in a heartbeat.
post #115 of 124 Old 04-26-2013, 05:34 PM
Liked: 4631
Live free or die.
Did I mention we also have one of the lowest rates of unemployment?
post #116 of 124 Old 04-26-2013, 07:07 PM
jbrown15's Avatar
Liked: 1993
Now you're just bragging! Lol
jbrown15 is offline
post #117 of 124 Old 04-26-2013, 07:18 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
I think he has been ever since we realized he gets scotch cheaper than us wink.gif
rick240 is offline
post #118 of 124 Old 04-26-2013, 07:19 PM
VicTorious1's Avatar
Quoted: 353 Post(s)
Liked: 292
I couldn't in good conscience by my liquor from a socialist state run liquor store. biggrin.gif
VicTorious1 is online now
post #119 of 124 Old 04-26-2013, 07:33 PM
jbrown15's Avatar
Liked: 1993
At least you only pay 5% tax Rick and not 12% like we do in BC!
jbrown15 is offline
post #120 of 124 Old 04-26-2013, 09:52 PM
Quoted: 146 Post(s)
Liked: 246
Well, I don't think being state run necessarily makes the liquor any cheaper. The liquor stores in Ontario are all state owned and they take that opportunity to completely rape their customers.
Reply Speakers
