New Official Axiom Audio Speaker Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #541 of 561 Old 09-03-2016, 09:20 PM
JewDaddy's Avatar
Quoted: 199 Post(s)
Liked: 98
I'll give it a shot. Thanks!!!!
JewDaddy is offline
post #542 of 561 Old 09-03-2016, 11:30 PM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
S
Originally Posted by JewDaddy View Post
Hey guys. I currently have a 7.1.4 Dolby Atmos and DTS-X setup. My question is in regards to expert opinions on the setting s for my speakers.
No expert here, but I have some experience. I use 80Hz sub crossover and set all speakers without woofers as small. Specifically, I'm 5.2.2, with Axiom M80, VP180, M80 in front large), 3 subs, and small side surrounds QS8s, top fronts CSW.
My theory is that speakers and accompanying equipment are designed around this default 80Hz crossover and small surrounds setup. So that's what we should use. That's probably the setting the engineers used when they were designing the internal speaker crossovers.
I went through a period of trying to avoid frequency holes by setting crossovers appropriately, but I could never get a better sound that way.
ereed likes this.
Greg Lee
GregLee is offline
post #543 of 561 Old 09-04-2016, 09:41 AM
ereed's Avatar
Quoted: 1316 Post(s)
Liked: 766
Show us your axiom system greglee!
Theater: Sony 45es, 120 inch 16:9 screen, Panny BDT500, Rotel RMB-1075, Rotel RSP-1068, Klipsch RP-280F, RP-450C, RP-160M, SVS PB13 x 2, Monster Power Conditioner, GIK acoustic panels
TV Room: Panasonic 60" plasma, Integra DTR-30.3, Axiom Audio M60, VP150, QS8, EP500
ereed is offline
post #544 of 561 Old 09-04-2016, 11:40 AM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
Code:
subs: EP500          JBLxx      Sonyxx
top/height:    CSW300        CSW300  (not Axiom)
front:           M80   VP180  M80
wide:       M22                        M22
side:   QS8               me                 QS8
back:     QS8                           QS8
But my current AVR does not power the front wide or back surround speakers.
Greg Lee
GregLee is offline
post #545 of 561 Old 09-06-2016, 06:26 AM
ereed's Avatar
Liked: 766
Originally Posted by GregLee View Post
Code:
wide:       M22                        M22
side:   QS8               me                 QS8
back:     QS8                           QS8
I was hoping for pics! Thats a lot of speakers!
ereed is offline
post #546 of 561 Old 09-10-2016, 08:51 AM
JewDaddy's Avatar
Quoted: 199 Post(s)
Liked: 98
For spl meter I use radio shack brand. The one I have is analog like this. Cost $39 http://www.mcmelectronics.com/produc...FYs9gQod2tYAPg
You will do this from your main listening position and hold the meter ear level and microphone angled 45 degrees to ceiling (not pointing at speakers) and it will remain this position the whole time. Ideally you sit in middle of tv and point meter towards ceiling at 45 degrees and HOLD it there and don't move. Turn on the meter and put it on C weighting and SLOW response and turn the level to 75 db reading. Now turn the volume up on your AVR during the test tones at the main speakers til it reaches 75 db on the meter itself (do not touch avr volume knob again after this point). Memorize the volume number on AVR (this is where you most likely will be using for movie playback). The needle moves on the meter and use your remote on avr and raise db up or down for each speaker level so it reaches 75db. If its over 75 db then turn down speaker level for that speaker a db or two. While holding still for test tones every speaker should be at exact reading as possible 75db on meter except for the sub which you can do last. For the sub, do the exact same thing but keep sub level on avr at "0" and just use svs amp to turn up til you read 85db on meter while in same position (you may have to get up to adjust and back to MLP a few times). All this does is get each speaker leveled matched so one speaker doesn't overpower the other and sound like director intended when you watch the movie. So while you're sitting and holding still and everything is quiet just run the test tones and each speaker should be 75db and sub at 85db. Then you're done! Feel free to adjust sub to your liking....if its too loud turn down sub at amp a little...if you want more turn it up a little. This process takes about 15 min overall.
Thanks again for your help here on the forums. I also sent you a pm about this. I bought the meter you suggested and I plan on running my speaker tests today when I get back. I've read over your instructions a couple times now and the only part I'm still having a question about is the level in supposed to set my AVR at while outputting test tones through the speakers.
I primarily run my volume levels while watching movies around -11 to -10 db. How exactly am I supposed to know which volume level to choose when using the test tones? Am I supposed to send the text tones from one of my main front speakers and adjust the volume until I get a 75db reading on the spl meter? If so, that confuses me because then I'm not sure if I'm supposed to increase or decrease the volume for the fronts because I'm testing it right where I'm supposed to at the 75db level.
I hope that didn't confuse you. Lol. Thanks for your help.
JewDaddy is offline
post #547 of 561 Old 09-10-2016, 11:30 AM
ereed's Avatar
Liked: 766
No worries, I sent you a PM as well in more detail. Good luck!
ereed is offline
post #548 of 561 Old 11-22-2016, 08:51 AM
jermar's Avatar
Quoted: 47 Post(s)
Liked: 31
I've had my modest Axiom setup since 2003 and I'm not planning on any changes other than a new OLED TV. I don't know why there isn't more interest in Axiom. My left F M22 is the wall mount version. It's great since it does not block the view when the TV is turned to the left, and we are in the kitchen. They play clean and loud.
Sony 65"A1E, Marantz 7005 Pre, Rotel 5ch X 120w, Axiom & HSU sub.
jermar is offline
post #549 of 561 Old 11-22-2016, 09:03 AM
ereed's Avatar
Liked: 766
I've also had my axioms since 2003/2004. Not many people with axioms in this forum. Axioms don't get alot of love in here.
ereed is offline
post #550 of 561 Old 11-22-2016, 11:24 AM
BuddTX's Avatar
Quoted: 110 Post(s)
Liked: 83
Love my Axiom M80's that I have owned since 2003 or so (V2).
Check out the Youtube video to see how complex the M80 design is:
Also very interesting, is that there are a LOT of speaker finishes available, both real wood, and vinyl veneer's.
Not a lot of speakers in this price range have this many options on finishes.
A solid speaker company, in the business for the long term.
When the US dollar was trading favorably compared to the Canadian Dollar, the Axiom's were a much better value to US citizens.
The issue is, that there are a lot of options in the price range of the Axiom M80's, that did not exist back then.
For instance, the M80's cost 1890.00 a pair, (1702.00 if you choose from their existing inventory) free shipping and no tax.
In that price range I would rather have a Philharmonic Slim (2200/pair) or a Ascend Acoustics Sierra Tower (1998 with the NrT tweeter).
But, if I were looking for value, the Emptek R55Ti Tower Speakers are 347.50 each! Wow! 700 bucks (shipping included) for a pair of towers. Never heard the R55Ti's, but they get lots of comments on AVS.
So, it is a very competitive market that the M80's are in.
But still, Axiom is a solid, serious speaker company, in the business for the long term.
BuddTX is offline
post #551 of 561 Old 01-11-2017, 02:36 PM
BuddTX's Avatar
Quoted: 110 Post(s)
Liked: 83
New Speakers from Axiom!
http://www.axiomaudio.com/new?utm_so...anuary_10_2017
To quote from their e-mail:
We've engineered floorstanding performance into our bookshelf and surround speakers for maximum sound quality
Today we are proud to introduce the M5HP bookshelf speaker and the QS10HP surround speaker. These small-for-the-sound speakers have the bass extension, power handling, and overall output capabilities of a traditional floorstanding speaker. The M5HP is also available in an on-wall and in-wall configuration.
Pre-order between now and January 17 for the biggest savings.
For more details and special pre-order pricing click here
Shipping March 2017
BuddTX is offline
post #552 of 561 Old 01-11-2017, 03:38 PM
ereed's Avatar
Liked: 766
Shipping March 2017
I saw that. Even look at their new QS speakers. Not much creativity there other than slapping on another driver. Seems like they don't really innovate new stuff, just add more drivers with same outdated look from 20 years ago and continue to increase prices. I've always liked my axioms since 2003 but after the upgrade bug recently, I have relocated it to a smaller room.
ereed is offline
post #553 of 561 Old 02-04-2017, 06:04 AM
jermar's Avatar
Quoted: 47 Post(s)
Liked: 31
ereed, you are right about not much new. However, I still love my M22s from 2003. What else sounds better and is a better value? I like the look of my black center cup speakers [post 548] much better than the dull white that's currently produced.
Anyone replaced Axiom with something they like better?
jermar is offline
post #554 of 561 Old 02-04-2017, 06:58 AM
ereed's Avatar
Liked: 766
I still enjoy my axioms and have it in another room as a small 5.1 with plasma tv. My theater room now (previously axiom) has new Klipsch RP line and I enjoy it alot more for movies. Axiom still sounds good, but the RP line gives me that cinema sound I'm looking for which is more dynamic sounding. But since I still like my axioms I found another room for them at tv setup.
Not trying to bash axiom here since I love my M60tis from 2004 but I feel like their current M60s looks EXACT the same but with updated drivers and I have a friend with v4 version and it sounds pretty much same as mine but slightly better, not double the price axiom charges now. So Axiom isn't best performance for the dollar anymore like they used to be. You also have a lot more competition that is cheaper than axiom and sound great these days. There wasn't many ID companies back then, now there are A LOT of them so you have more options. Would I buy axiom again? Not for the prices they charge these days. But will I keep mine I currently have? Absolutely since they sound great and for the price I paid back then. LOL
ereed is offline
post #555 of 561 Old 06-11-2017, 08:12 AM
timjohnson1717's Avatar
Quoted: 85 Post(s)
Liked: 81
I have a pair of QS8's and they work great for filling the back of the room, I bought them because the room was deep enough for a 7 channel setup, so I am using 5 with the QS8's in the rear. Would I buy Axiom again? Sure, for surrounds, comparing the QS8 to the Aperions in the front, they are excessively bright. The Front sound much more natural and balanced. I am not going to say Axiom is terrible, because they aren't, but that I am not a huge fan of the tonal balance. When I move out of the apartment, and have a dedicated HT room, I will likely move to 7 channel and replace the QS8's with their Aperion counterparts.
timjohnson1717 is online now
post #556 of 561 Old 08-24-2017, 04:38 AM
the safari man's Avatar
Question
Hey all! I'm trying to figure out my family room configuration for our new house, and came across Axiom on-wall speakers as a possible solution to my problems. To lay it out, we're talking about a 450 sq ft room with a vaulted ceiling about 18 ft high, and a brick fireplace on the main wall that runs all the way to the ceiling. We kind of need to mount the TV on the fireplace, and are building a mantle to hold my Klipsch RC-35 center channel below it. I normally pair that with RB-10 for fronts, and RS-25 for the surrounds, along with a KSW-12 sub. All of this would be powered by my trusty Marantz SR6006.
Due to the layout of this family room, we're looking at keeping the fireplace area pretty clean, without any cabinets or clutter, so I would be running everything discretely under the floor (basement is below, thankfully) and through the walls, with the receiver, Apple TV, Xbox, and turntable all in the back of the room. This means that I have no place to put my front channels other than the mantle, which I'm not wanting to do.
So, my question is if it might make sense to utilize a pair of Axiom on-wall speakers as my front channels in such a system, replacing the RB-10s? While many find Klipsch to be a bit bright, I love their sound, and am a tad worried that the more-neutral Axioms might dull down the surround effect? I'm not as worried about the 2.1 listening setup for my records, but general TV watching, gaming, and movies might be a bit more subdued than I'm used to when in 5.1 mode.
Further to this, what fronts should I be looking at, given my room size? I'm inclined to get some factory outlet M22s which might project a bit better in a taller room such as this, but maybe I don't need to go that big, and would be happy with the M3? Need some advice on this front too...
the safari man is offline
post #557 of 561 Old 08-24-2017, 03:19 PM
ereed's Avatar
Liked: 766
Whatever you decide...just make sure all front 3 are same brand for timbre matching. If you do decide to keep Klipsch maybe look at their in wall RP line. Or go axiom. Either way, you will have great system.
ereed is offline
post #558 of 561 Old 08-25-2017, 05:26 AM
Oh really?? I didn't think that mattered so much. I mean, I'm talking about a 5.1 system which will be listened to by a wife and very young child - not trying to impress anyone with the TV or movie sounds, so if the 5.1 doesn't match perfectly, we'll survive. If it's going to make me nauseus like the system is out of phase, then I can't do that, but is this really anything someone other than an audiophile would hear? My 2.1 system, which would then be 2 Axioms with the Klipsch sub, I think will be OK together - and that's the only real audio performance I care about!
post #559 of 561 Old 08-25-2017, 06:42 AM
ereed's Avatar
Liked: 766
While not every speaker has to match but the front 3 (left/center/right) should match as close as possible. You want all the sound up front to be similar when sounds go from left to center to right of screen. The surrounds and subs do not have to match. Subs definitely do not need to match. Personally if it was me knowing I have 2 axioms, I'd go with axiom center channel as well. If you are not happy with it, you can always change it to your liking.
ereed is offline
post #560 of 561 Old 08-25-2017, 09:40 AM
newfmp3's Avatar
Quoted: 289 Post(s)
Liked: 266
Yes, match all 3 fronts at least. I have M22, M3, and M2 and VP-150 on walls in a small room. They do well. The M22's are actually my least favorite but they are V3's vs the rest being V4's. The M2/M3 have more bass, the M22 on walls have very weak bass but if you have a decent sub, no worries. I also replaced my QS8's with M3 on-walls for my rear surrounds for Atmos and that was a nice upgrade. If you got the money go for their new on walls M5hp.
Remember, Axiom has 4 ways to buy speakers. New, Factory outlet, Refurb, and B-stock. Personally their prices have sky rocketed over the years and I don't see buying them New as much of a bargain as they used to be. Factory outlet is as good as new, as I don't see any difference in my "new" ones vs them. A B-stock in excellent in condition is equally as good usually. Anything that says scratch and dent, probably avoid. I'm in Canada, so my options are limited, and Axiom treats me very well. They also have excellent black Friday sales.
I have a LOT of Axioms...lots. Ep800 real knotty pine, two Axiom Air's, EP500, M80, QS8, VP-150, on wall VP-150, VP160, four M3 bookshelves real knotty pine, on wall M3/M2, four in ceilings with aimable tweeters M3's. Also have HSU, several SVS subs PB2k/SB2k, Paradigm, Polk, even old Vega D9's in the house as well. Their real wood options are gorgeous and resemble high end furniture more than speakers. Their Vinyl is excellent as well with my oldest ones being 13 yrs old and look like new. SVS in my opinion make the worse Vinyl I've ever owned of any speaker/sub with all mine bubbling and peeling within months.
There are about 3-4 people here that have bashed Axiom over the years for their own benefit to further other brands. Try them, send them back within 30 days, use your own ears to judge.
ereed likes this.
newfmp3 is offline
post #561 of 561 Old 08-26-2017, 06:23 AM
I decided to give it a shot, and ordered a pair of refurb on-wall M5HPs, and a factory outlet VP150. I'll keep my Klipsch surrounds and sub for now, and hope that my Marantz can do those front channels justice. I don't imagine I will have a power deficit as this is a pretty substantial unit, but might I need a separate amp for the M5HPs?
Reply Speakers
