Advice on Harman Kardon HKTS 30 vs Energy Take Classic 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-19-2013, 09:33 AM - Thread Starter
davidjbak's Avatar
Hey guys I'm hoping someone here has listened to both of these sets and can offer some advice.
Basically I have an opportunity to get a big discount on Harman Kardon speakers and wanted to keep my budget around 300-400. Now I know that Cnet had said the HKTS 20 sounded a tad worse than the take classics and was more expensive so why buy them. So my question is....
1. Not considering price which system would sound better the HKTS 30 or Take Classic?
2. Anyone know if there's a big diff in HKTS 30 vs the HKTS 60?
davidjbak is offline
post #2 of 5 Old 03-19-2013, 10:50 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The HKTS30 has dual 3.5" drivers while the HKTS60 has dual 3" drivers so I'd get the 30 between the two. The subwoofer looks the same.
Are you required to have satellite size speakers? If not there are better choices such as the Andrew Jones Pioneer speakers.
How big is your room?
Afro GT
afrogt is online now
post #3 of 5 Old 03-19-2013, 11:32 AM - Thread Starter
davidjbak's Avatar
Thanks for the reply.
I am sticking to smaller speakers because my room isn't very large. The pioneer speakers would be way to big.
Now I know on paper the hkts 30 should be better because of the dual drivers but I keep hearing how the take classic has amazing "sound quality". I don't need these speakers to get extremely loud I listen to movies at moderate levels and care for the quality of sound.
I just haven't really been able to find reviews on the hkts 30.
post #4 of 5 Old 03-19-2013, 09:23 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
A Harman Kardon HKTS 30 review: http://www.hometheater.com/content/harman-kardon-hkts-30-speaker-system
I'd also look into the Martin Logan MLT-2 in your budget range.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 5 Old 03-19-2013, 09:24 PM
cel4145's Avatar
Liked: 2985
Oh, and the MLT-2s are rebadged Paradigm Cinema 90s. Here are two reviews:
http://reviews.cnet.com/separate-speakers/paradigm-cinema-90/4505-7869_7-7934264.html
http://www.hometheaterhifi.com/volume_9_3/paradigm-cinema-speakers-9-2002.html
The sub might be different (not sure), but the speakers are the same.
cel4145 is offline
Reply Speakers
