Rule for toe ing in speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-20-2013, 02:53 PM - Thread Starter
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
Is there a rule when you should or should not toe in your fronts? I have horn speakers and I have read both ways. I know that its up to me in the end what I like, but I was just wondering if there is a said rule, like how many degrees or like crossing 2 feet in front of the sweet spot or what? thanks in advance for the reply's. If It matters at all I have bic pl-89s for the fronts.
metalguy is offline
post #2 of 7 Old 03-20-2013, 03:50 PM
Resonate's Avatar
With the Hsus my intersection was like a foot in front of the main position but iirc more distance would be ok and maybe even better. I'd think the bics would mention something about it in the manual or on their site.
Resonate is offline
post #3 of 7 Old 03-20-2013, 04:55 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
For certain horn-loaded speakers, toe-in in front of the listening position is sometimes suggested as the first reflections set up from that angle can create a wider soundstage by hitting the other side of the listener. That is the theory anyway.
shadyJ is offline
post #4 of 7 Old 03-20-2013, 06:27 PM
Resonate's Avatar
Resonate is offline
post #5 of 7 Old 03-26-2013, 09:15 AM - Thread Starter
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
Anyone else want to chime in
metalguy is offline
post #6 of 7 Old 03-26-2013, 09:23 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Klipsch big horns work best aiming right at you so you can see down the throat of the horns. What makes it obvious that you have it right is when they completely disappear from the room, leaving only point sources of voices and instruments.
psgcdn is offline
post #7 of 7 Old 03-26-2013, 10:18 AM
Bill Fitzmaurice's Avatar
Liked: 4947
Almost always. But how much varies, depending on how far apart they are and how distant the listening position. When perfectly aimed you can close your eyes and hear center panned sounds coming from the so-called phantom center. But the size of the sweet spot where you'll get that effect isn't all that large, and is something best appreciated when listening to stereo sources though L/R speakers. With more than a 2.x source and a center speaker imaging isn't much, if any, of a concern.
Bill Fitzmaurice is offline
Reply Speakers
