Help me choose - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-21-2013, 01:12 AM - Thread Starter
endy0430's Avatar
Getting ready to purchase my new fronts and have narrow it down to the 2 following options
1-Klipsch RF-52 II
or
2-B&W 685B
What is a better choice, I have a Pioneer VSX 53 as my receiver.
Mostly they will be use for movies and music.
endy0430 is offline
post #2 of 3 Old 03-21-2013, 05:25 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
If you aren't using a sub, go for the Klipsch towers. If you are using a sub, you might think about some KEF Q300 bookshelf speakers instead. They are the same price and I would rather have the Q300s than either Klipsch or B&W.
shadyJ is offline
post #3 of 3 Old 03-21-2013, 06:27 AM - Thread Starter
endy0430's Avatar
Yes I'm using the a sub, I have the Klipsch RW-12D.
Also the room is not a large room.
endy0430 is offline
Reply Speakers
