What could be causing woofer reverb?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-22-2013, 12:40 PM - Thread Starter
Daffypuck's Avatar
Quoted: 42 Post(s)
I have a set of speakers I picked up for a friend off of Craigslist that for some reason at higher volumes seem to what I call "reverb" through the two woofers. It goes away if you quickly turn it down then back up. I wondering if incorrect polarity could cause the problem. A better way to describe it is that the cones just push out and hold creating a continuous LF hum that grows. Any ideas? At the time I didnt think of checking the speaker wires because I have faith I connected them properly. But now Im left wondering.
(they are the type of speakers with a tweet, mid and two 8 inch woofers)
Daffypuck is offline
post #2 of 3 Old 03-22-2013, 01:53 PM
Bill Fitzmaurice's Avatar
Liked: 5687
The speakers would not cause that, a bad amp would.
Bill Fitzmaurice is offline
post #3 of 3 Old 03-22-2013, 02:00 PM
wronganswer's Avatar
A bad woofer suspension can cause that.
wronganswer is offline
Reply Speakers
