NHT speaker - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #61 of 84 Old 08-29-2014, 07:39 PM
ben1492's Avatar
Liked: 0
I added a photo from zillow of the previous owner's setup, circling the speakers. They had the center and the right front sitting side by side. I will be mounting a flat screen above the fireplace and putting the center either above or below the TV.
Name:	Previous Setup.jpg
ben1492 is offline
post #62 of 84 Old 08-29-2014, 08:48 PM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 194 Post(s)
Liked: 219
Hi Ben,
Since your location looks like you need to keep the speakers in a horizontal position (if using the same spots), I'd recommend the NHT M5's (they can only found as used). There is a set on Ebay right now:
http://www.ebay.com/itm/NHT-M5-Books...item4adb0d21f0
If you can give us the measurements of the area you want to place the sub-woofer, that would help a lot on recommendations.
ben1492 likes this.
Ray
"Listen with an open heart and mind."
cavchameleon is offline
post #63 of 84 Old 08-30-2014, 09:59 AM
ben1492's Avatar
Liked: 0
Originally Posted by cavchameleon View Post
Hi Ben,
Thanks so much. I just put an offer in for those two speakers, and will keep my eyes peeled for a 3rd to use as a center. We are out of town for Labor Day, so I can't measure the space for the subwoofer in the cabinet. I will do so on Monday when I get home. I'm guessing the cabinet space is at least 16WX24DX36H. I circled the cabinet where it would go in the new photo...there are no shelves on the side for the subwoofer, so I can use the entire space.
ben1492 is offline
post #64 of 84 Old 08-30-2014, 10:14 AM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
Your plan to put the TV in the center of the room will be a great improvement (even though a position above the fireplace will have its own challenges). Your front speakers don't have to match the surrounds, but NHT speakers use a sealed acoustic suspension design and are one of the few "bookshelf" speakers that actually work well on a bookshelf.
NHT Evolution M5
Dimensions 7.75"W x 17.75"H x 8.5"D
The used Evolution M5 are a great idea if they fit and the seller is willing to guarantee their safe arrival. I've bought used speakers and had them shipped, make sure the seller ships in original boxes and ask for double box or wrapped in an additional layer of cardboard. "Professional" packing by a shipping store is a joke and not sufficient to get them to you undamaged. I would also check to see if the speaker grilles are available from NHT in case they are damaged (NHT sent me a free grille one time!) - they often are damaged in shipping.
The reason these speakers will work well horizontally is the tweeter over the mid-range, this gives the speaker better horizontal dispersion (spread of sound) and makes sounds and dialog clear and understandable from any location in the room. The new NHT center speakers also feature this design an would work equally as well if you want to buy something new
Horizontal L, R, Center: NHT TwoC Center Channel Speaker
ben1492 likes this.
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #65 of 84 Old 08-30-2014, 11:31 AM
zieglj01's Avatar
Quoted: 941 Post(s)
Liked: 846
That is a good option for you - and that is a good Ebay seller, with a 99.8% rating for over 5,800 reviews.
They do deal with a lot of speakers, and test their speakers out.
http://www.ebay.com/sch/Home-Speaker...=valueauctions
The Evolution speakers do tend to pop up again from time to time - there is a nice chance that
you will find another one.
ben1492 likes this.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #66 of 84 Old 08-30-2014, 04:48 PM
Quoted: 194 Post(s)
Liked: 219
Agreed! Keep an eye out on Ebay for another Evolution M5. I'd suggest you also check your local Craigslist as they have popped up here once in a while. They were a great series of speakers!
As for the sub, since you're placing it within a cavity, I'd recommend a sealed version. If going with a ported one, make sure it's a front facing port.
mtn-tech and ben1492 like this.
Ray
post #67 of 84 Old 08-31-2014, 12:10 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
+1 - internet direct subs give you a lot more for your money - SVS is a good one and both sealed and ported subs are front facing (drivers and ports):
http://www.svsound.com/subwoofers/ported-box
http://www.svsound.com/subwoofers/sealed-box
ben1492 likes this.
mtn-tech is offline
post #68 of 84 Old 08-31-2014, 02:46 PM
ben1492's Avatar
Liked: 0
Thanks, everyone, for the advice. I went ahead with mtn-tech's recommendation and bought an NHT TwoC center channel. I'm down to two options in my price range for the subwoofer and would like some opinions before pulling the trigger:
This:
http://www.ebay.com/itm/NHT-Twelve-H...item2a423b93b6
Or this:
http://www.ebay.com/itm/SVS-SB-1000-...item23386c3b1b
ben1492 is offline
post #69 of 84 Old 08-31-2014, 03:41 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
Both NHT and SVS make very good low priced subs. All other things being equal (power, woofer size, etc) ported subs will play lower and louder and are considered by most to be better for home theater, sealed subs are smaller and less boomy and are considered by most to be better for music.
If you want very smooth, balanced, loud bass the tradeoff is to get two (possibly smaller) subs - this wiLl increase your placement options and smooth out your bass.
If you buy an SVS sub, I would recommend buying it directly from them - their return policy and "buyer bill of rights" are very good benefits and the prices are the same as other sellers.
ben1492 likes this.
mtn-tech is offline
post #70 of 84 Old 09-01-2014, 12:11 AM
Quoted: 194 Post(s)
Liked: 219
This:
Or this:
That NHT model is one of their older ones that is ported. Their newer ones are sealed designs:
http://www.nhthifi.com/Subwoofers
The other dealer is a certified SVS dealer (onecall.com or their ebay store). But as mtn-tech stated, it's better to get it directly from SVS as it's the same price with free shipping included:
SVS is a great ID company that backs their equipment, hard to beat customer service, and great products.
ben1492 likes this.
Ray
post #71 of 84 Old 09-05-2014, 11:31 AM
ben1492's Avatar
Liked: 0
Coming back to the well one more time. The installer recommended that instead of using the NHT TwoC I go with an In-Wall speaker for the center channel. I'm using a subwoofer, so do I gain anything if I go with the NHT iW4 as opposed to the cheaper (and "useder") iW3?
ben1492 is offline
post #72 of 84 Old 09-05-2014, 03:11 PM
JimWilson's Avatar
Quoted: 1270 Post(s)
Liked: 1579
Run from that installer. A center is probably the worst speaker to mount in a wall, so I would pass on that suggestion. To be honest, anything in the front stage is a bad idea. Surrounds are OK if they're oriented properly in relationship to the viewers, so you might be able to get away with doing that, but I would suggest you don't do any in-walls for the fronts.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #73 of 84 Old 09-05-2014, 05:44 PM
Quoted: 194 Post(s)
Liked: 219
I would have to agree. For the most part, most inwall/inceiling speaker cannot match speakers in a well designed box and are compromises. There are some like Triad that make incredible inwall/inceiling speakers, but the are not cheap. Any speaker with an open back in a wall or ceiling will create a resonant frequency in the wall (just do to the sheet rock itself and how the wall is made) that cannot be avoided. Having said that, I do have in wall speakers in our bedroom (request of my wife), but would not use them in a main system. I also built 'back boxes' for them and stuffed the cavities up to adjoining studs (and caulked the sheet rock to the studs on the inside).
The choice is really up to you, but you'll have some incredible L/R speakers that will be highly compromised by an in-wall center. If you 'have' to do it, go with the iW4. If you can get a matching center to your L/R, go with that route. As Jim stated, the center IS the most important speaker for home theater bar none. Just food for thought...
Ray
post #74 of 84 Old 02-09-2015, 08:31 PM
ghstudio's Avatar
Is nht still in business. I need some technical help on my emb-1200.
ghstudio is offline
post #75 of 84 Old 02-09-2015, 08:52 PM
willieconway's Avatar
Quoted: 121 Post(s)
Liked: 130
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is offline
post #76 of 84 Old 02-09-2015, 09:06 PM
CptSpig's Avatar
Quoted: 37 Post(s)
Liked: 36
NHT Service
NHT has very good customer serivce.
CptSpig is offline
post #77 of 84 Old 02-10-2015, 07:05 AM
Quoted: 194 Post(s)
Liked: 219
Agreed, just give them a call. They will respond quickly and will get you to the right person to deal with your issues.
Ray
post #78 of 84 Old 03-03-2015, 12:46 PM
poochpa's Avatar
Quoted: 45 Post(s)
Bought a pair of Classic 3s in November and have been enjoying them ever since. Despite the fact that I've had to place them on their sides in an enclosed bookshelf cabinet six feet up, they sound great. Went with the NHTs because they are one of the few makers of acoustic suspension speakers left and a ported speaker would not work well in the enclosed shelf space I have. The C3s are paired with a BA 10" sub and the combination works well with my Denon AVR. Primarily listen to classical music and the NHTs provide a good flat response and incredible detail. Treble was a bit harsh until the speakers were broken in, which didn't take long. They are unforgiving if the source is not of the best quality. However, listening to hi-res flacs with these speakers is an absolute joy.
Mike
poochpa is offline
post #79 of 84 Old 04-21-2015, 03:30 PM
Liked: 0
Hi all,
Newbie on the board. I used to live in Chicago and there were quite a few NHT dealers, so I amassed a selection of items that are now sitting in storage. Way before the days when they were sold off to Recoton.
My question is this, I have a pair of circa 1990 SuperZero's, 1.1's and the CC1.1 Center channel.
Is there a market for selling these? I now live in Seattle and I'd have to have them shipped out to me. I do love the look still, gloss piano black.
Thanks for any help you all can provide!
andy chan is offline
post #80 of 84 Old 04-22-2015, 08:36 AM
JimWilson's Avatar
Liked: 1579
Originally Posted by andy chan View Post
NMy question is this, I have a pair of circa 1990 SuperZero's, 1.1's and the CC1.1 Center channel. Is there a market for selling these? I now live in Seattle and I'd have to have them shipped out to me. I do love the look still, gloss piano black.
For someone into vintage items perhaps, but 25 year old speakers probably won't have much interest beyond those folks.
post #81 of 84 Old 04-22-2015, 03:27 PM
zieglj01's Avatar
Quoted: 941 Post(s)
Liked: 846
Hi all,
There older products still move/sell on Ebay
Who AM I
zieglj01 is offline
post #82 of 84 Old 04-26-2015, 07:12 AM
Quoted: 60 Post(s)
Liked: 48
Even though I received my pair of NHT SuperOne 2.1's Christmas Eve, via Amazon's 2-day s&h, I wouldn't open them until after returning from the in-law's for Christmas dinner. Good thing, or I'd never have left the house that day. I had never seen or heard NHT speakers - I wasn't ready for the shock! My first thought as I pulled the first one from it's box was that I needed white cotton gloves. After connecting them to the already in-place set of matched length #16 copper zipcords and placing them alongside my existing Infinity P163's, I proceeded to A-B them. I expected to have to 'ride' the gain pot on my Onkyo TX-8020 - and I wasn't disappointed. Oddly, it's 50 Wpc seemed sufficient, too, for my 11' x 12' office 2.0 system - with mainly a C-7030 CDP, but my PC's 25" monitor and an old Sony BR are available, too. The NHT's have a crystal clarity and controlled bass reminiscent of my Advent Large loudspeakers from four decades earlier. Although both had 6.5" LF drivers, the front-ported bass reflex of the P163's seemed to be bass-heavy - with hangover. They had been an improvement over my two decade plus previous HT speakers, Polk Large Monitors. They were in turn replaced by P363's in my new home's HT. The P163's followed the Polks to my upstairs 'hobby' room within a week... the NHT's had won the A-B contest.
I had to 'try' a pair of Klipsch KB-15's (5.25" LF/horn loaded dome HF - SPL>93 db!)... they were $130/pr delivered. They were A-B - ed for a month - they really sounded great, too... second best in midrange and wide soundstage - just not quite as good as the NHT's, although they were more sensitive than even the Infinity's and the Polks. Their rear port made real bookshelf placement possible only after clearing the bookshelf. I added an old Sony 10" powered sub - too much hangover (I like 'BOOM!' - not 'BOOMmmm!') - I threatened to 'borrow' the HT's Polk PSW-505. Then, I found the acoustic suspension JBL SUB 550 - and I found it in cherry for < half price, too. Wow! The Klipschs sounded good - but the sound of the NHT's is very, very, good... add the JBL sub, and it becomes excellent. The KB-15's are in the upstairs hobby room.
I am glad I read the positive remarks re the NHT line both here and on other forums & threads. I am really glad I ordered my pair. A-B - ed with the P163's in my upstairs hobby room, the Klipsch's won the recycled war there and are my workbench stereo/mini HT speakers. The NHTs - with the slight assistance of the JBL sub-woofer - make the best sounding stereo system I've ever owned.
Stainz
Stainz is offline
post #83 of 84 Old 04-26-2015, 07:49 AM
Quoted: 194 Post(s)
Liked: 219
Stainz
Glad you like them! Yes, NHT makes great speakers for the price. I was introduced to them back in the 80's and was impressed with their sound compared to the competition. All the NHT bookshelves do need a sub though, as do all other bookshelf speakers.
Enjoy!!!
Ray
post #84 of 84 Old 11-10-2015, 06:00 PM
menocu's Avatar
I'm very interested in checking out NHT's SuperOne 2.1, possibly using them as matching vertical LCR in a 5.1 setup. Anyone had them for awhile and can comment on them?
dougdabbs likes this.
menocu is offline
Reply Speakers
