Noobie and need speaker help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 03-25-2013, 07:14 PM - Thread Starter
jayzlookz's Avatar
Hello everyone. I have been lurking for quite some time but now my eyes are burning. I need a little help with my theatre room setup. My room is around 25'X15'. I plan on purchasing the Sony STR-DN1030, Denon AVR 1613,1913 or the ONKYO TX NR616 since they fall into my budget and the reviews were pretty good. I have several question about speakers and my setup. I have been searching differnet post but a lot of the speakers mentioned or suggested I have never heard of before. I only know the big box names sold in Best Buy like Bose, Sony, Pioneer, etc. My budget is around $800 for speakers. Should I buy a box set or seperates. I am leaning towards center speaker, L/R speakers, 2 rears. Does this sound OK. Any help would be greatly appreciated.
jayzlookz is offline
post #2 of 28 Old 03-25-2013, 07:21 PM
wronganswer's Avatar
In my opinion ,Pioneer will give you the best sound. You can get the 2 floorsranders, center and 2 bookshelf and the denon 1613 for less than $800
wronganswer is offline
post #3 of 28 Old 03-25-2013, 07:50 PM
gromicide's Avatar
X2 On The Pioneers.
gromicide is offline
post #4 of 28 Old 03-25-2013, 10:19 PM - Thread Starter
jayzlookz's Avatar
Any particular brand?
post #5 of 28 Old 03-26-2013, 12:38 AM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
Pioneer is a brand....and Best Buy only sells one Pioneer tower, one center and one bookshelf speaker model.
Afro GT
afrogt is offline
post #6 of 28 Old 03-26-2013, 01:23 AM - Thread Starter
jayzlookz's Avatar
I meant size instead of brand. I see that Best Buy only sells one style. They seem to have really good reviews. I guess I'll check that out tomorrow. Thanks.
post #7 of 28 Old 03-26-2013, 09:33 AM
robotolove's Avatar
I suggest staying away from the all in one box speakers. But at the same time don't get 5 different speaker brands. Try and pick up a set of matched speakers so that all your speakers have the same "voice," so to speak. I like the Infinity Primus series. If it's out of your budget, check craigslist or Amazon. Good luck with your set up.
robotolove is offline
post #8 of 28 Old 03-26-2013, 10:32 AM
Pioneers are matched speakers.
post #9 of 28 Old 03-26-2013, 10:43 AM
robotolove's Avatar
Yes, the Pioneers are matched. I was just suggesting not to mix and match.
post #10 of 28 Old 03-26-2013, 11:05 AM
Elihawk's Avatar
Quoted: 1017 Post(s)
Liked: 861
My ears tell me, having heard all three..
Infinity primus > Polk monitor > pioneer
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #11 of 28 Old 03-26-2013, 12:26 PM
robotolove's Avatar
Are you suggesting to mix those speakers or are you saying those are your top 3 suggestions? I gotta say I love the Primus series. I'm running with Infinity Alpha 50's for my fronts right now but first chance I get I'm scooping up some Primuses
post #12 of 28 Old 03-26-2013, 12:59 PM
The point is to buy the speakers from the same brand, and get what sounds best to your ears.
post #13 of 28 Old 03-26-2013, 03:27 PM
robotolove's Avatar
Exactly, don't just go out and blindly buy whatever this forum suggests, sit down and audition different sets and listen to what your ears tell you... and then decide on the Infinity Primuses. Hahaha!
post #14 of 28 Old 03-26-2013, 03:57 PM
Dan Hitchman's Avatar
Quoted: 3414 Post(s)
Liked: 1767
Of the receivers you mentioned, I'd go with the Denon 1913. Stay away from Sony electronics.
Check out the Ascend CMT-340 SE and CMT-340 SE center. Get the surrounds (like the matching HTM-200 SE) a little later, if you must, since the left/center/right would be right at your current speaker budget. Or, just go for it, stretch it a bit, and ask for their package discount. They also have a deal where you get a discount on the fillable pedestals for the CMT-340 SE's if purchased at the same time (to make them full height towers). Better bang for your buck. Why not be happier at the start? Then add a subwoofer a little later.
http://www.ascendacoustics.com/
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #15 of 28 Old 03-26-2013, 05:30 PM
Infinitys are good stands for pioneer bookshelfs
post #16 of 28 Old 03-26-2013, 06:28 PM
robotolove's Avatar
post #17 of 28 Old 03-26-2013, 07:46 PM - Thread Starter
jayzlookz's Avatar
OK I went to Best Buy and listened to the Pioneer and other speaker setups. Compared to the Klipsch and Polk Audio speakers, they didn't sound as well. Is it the price point that make them so attractive? What is so bad about Sony receivers?
post #18 of 28 Old 03-26-2013, 10:07 PM
robotolove's Avatar
When it comes to Sony, in my opinion, they are a Jack of all trades, master of none. Sony makes TV's, Playstation, computers, car stereos, movies, etc. As far as I know Onkyo and Denon only make A/V gear. Know what I mean?
post #19 of 28 Old 03-26-2013, 10:20 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
It's how good they sound for the price that is attractive. That said, what sounds good depends in large part on personal preference. There are many who would say that Klipsch and Polk Audio speakers, especially in this price range, are screechy and almost painfully "bright." The lower-end Polk and Infinity speakers also have fairly readily audible cabinet resonances that "color" the sound, and not in a good way. To my ears, the latest Pioneer speakers avoid these issues, and pretty much do everything right--and as a result sound right--within their limitations as budget speakers. Obviously not everybody would agree, though, which is why it is important to audition speakers if you can and care to.
Robert Cook is offline
post #20 of 28 Old 03-26-2013, 11:56 PM
Liked: 1767
As for Sony receivers... let me count the ways. They're piles of junk. Just ask a neighbor of mine and a few other friends who have bought Sony receivers only to have them go bad. Their TV's are better, thankfully.
Denon and its sister Marantz, while a bit more expensive for the features, seem to have a better reputation. Onkyo used to, but seems to have slipped a bit. Not as bad as Sony, though.
post #21 of 28 Old 03-27-2013, 12:10 AM
sven1olaf's Avatar
i second the "stay away from Sony receivers" notion as well. before you buy anything, check out a local Home Theater specialist. you might be pleasantly surprised what you can get for the money.
"Great spirits have always encountered violent opposition mediocre minds..." A. Einstein
sven1olaf is offline
post #22 of 28 Old 03-27-2013, 03:38 AM
You have done the right thing by listening by yourself. Polk and Klipsch will sound better because those have greater sensitivity, they play louder with less power. Lower end Sony recievers dont sound as good as lower end Denons, Pioneers and Yamahas.
post #23 of 28 Old 03-27-2013, 02:30 PM
Quoted: 34 Post(s)
Liked: 55
Well, there is more to sound quality than efficiency, although that is an advantage in itself. It is true, however, that a speaker that is playing slightly more loudly than another at a given setting on the volume control will tend to sound better to most people, which is why it is important to match the speakers being compared in actual loudness before comparing them. This is the only way to be fair.
post #24 of 28 Old 03-27-2013, 04:19 PM
That would be true a few years back, but all the eq software in modern avr's make speakers sound the almost the same.
post #25 of 28 Old 03-27-2013, 05:28 PM
Quoted: 34 Post(s)
Liked: 55
This would depend on how things are set up in the store when doing comparisons.
post #26 of 28 Old 03-27-2013, 05:38 PM
Kini62's Avatar
Quoted: 1421 Post(s)
Liked: 1307
Originally Posted by Dan Hitchman View Post
As for Sony receivers... let me count the ways. They're piles of junk. Just ask a neighbor of mine and a few other friends who have bought Sony receivers only to have them go bad. thankfully.
More internet FUD. I had one for 11 years (it eventually died). The newer Sony AVRs like the one the OP listed have been getting good to excellent reviews. Sound wise there is nothing that separates any of the entry level AVRs. Most reviews of the Sony mention that Sony's ARC worked just as well as Audessey did in the lower end Denon's.
There are device failures in all brands.
For the OP, get the one that you like best and best fits your budget. Don't let a bunch of anonymous internet "experts" sway you.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #27 of 28 Old 03-28-2013, 01:50 PM
Liked: 1767
It's not FUD, if I've actually known too many people that bought Sony receivers and had problems of one sort or another with them. My neighbor had a nightmare dealing with Sony trying to get his fixed. They finally gave him his money back. He got a Denon instead and it's been trouble free.
Certain brands have better reputations than the basic Sony brand of receivers.
post #28 of 28 Old 03-28-2013, 03:11 PM
Kini62's Avatar
Liked: 1307
Just because YOU know a person or two who claims to have had trouble doesn't make it so that the everyone will have trouble. 2 or 10 out of 10,000,000? I know people or a person who had trouble with a Chevy and then bought a Ford that had no problems so now all Chevies are unreliable and all Fords are trouble free??? Makes about as much sense. rolleyes.gif
Def Tech SC8000
Reply Speakers
