Just bought mythos 8 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-27-2013, 11:58 AM - Thread Starter
Brad Sutliff's Avatar
Can i use it as a Center channel only with my previous L/R speakers?
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #2 of 4 Old 03-27-2013, 01:38 PM - Thread Starter
Can some one please help. Can i use it as a center only? or do i need to set it up as LCR and then use my other two fronts i have now as front highs? im not realy sure if the first would work or if the second option would be better? Thanks
post #3 of 4 Old 03-27-2013, 05:35 PM
Robert Cook's Avatar
Quoted: 34 Post(s)
Liked: 55
Sure, although it would be best if your front three were a matching set. What L/R speakers are you using right now?
Wait a minute, maybe I'm misinterpreting what you said, but you appear to be implying that the Mythos 8 is a soundbar. Actually, it's just a single speaker.
Robert Cook is offline
post #4 of 4 Old 03-27-2013, 05:37 PM - Thread Starter
yeah i got confused while looking at its owners manual. it showed multiple connectors in a diagram. anyways im using hd300 sats right now. from my first HT system. and now im slowly upgrading. because i have a small budget
Reply Speakers
