SPEAKER HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 03-27-2013, 07:00 PM - Thread Starter
notslip0602286's Avatar
I just got a brand new pair of Mordaunt-Short Aviano 6 speakers today as well as a used Denon 2811 receiver. I single wired the speakers and plugged in my ipod. They sounded great at first and then I turned up the volume a bit to test it out. It got relatively loud, for my smallish room, and then the tweeters and one of the mid range/bass speakers in each of the aviono 6s stopped playing. Only one midrange plays in each, and its the same on each tower. Any ideas what could be wrong? Could it be the receiver or the speakers? I'm pretty new to home theatre so dont know much. Thanks for your help!
notslip0602286 is offline
post #2 of 18 Old 03-27-2013, 07:18 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
I recommend that you try the following and test after each step:
1) look for any blown fuses in the receiver or speakers;
2) do a reset of your receiver;
3) use a different receiver; with your MS speakers; and
4) use a different set of speakers with your Denon.
audit13 is offline
post #3 of 18 Old 03-27-2013, 09:04 PM - Thread Starter
ok i dont have another pair of speakers or another receiver, how do i check the fuses? thanks!
post #4 of 18 Old 03-27-2013, 09:13 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
"then I turned up the volume a bit to test it out" Did you turn it up to eleven? You may have simply damaged the speakers and it may not be visible.
What do you mean by single wire? You mean you connected them normally and didn't do the silly bi-wire thing? Assuming the speakers have two sets of binding posts, were the jumpers/tabs in place?
The fuse on the avr is probably on the back panel and pretty easy to find; many speakers don't have fuses and if they're not obvious they probably don't have them but you can always check the manuals.
lovinthehd is offline
post #5 of 18 Old 03-27-2013, 09:19 PM - Thread Starter
lol i didnt turn it up to 11, i did turn it up but definitely not to 11, and yes I was refuting to bi wiring, but im pretty sure that want make a difference lol. i cant locate a fuse in the speakers so im assuming they dont have a fuse like you said. The speakers are definitely not blown thats for sure. Im still trying to locate where the fuses are on the denon, having some trouble locating them....
post #6 of 18 Old 03-27-2013, 09:29 PM
lovinthehd's Avatar
Liked: 4783
Does sound like at least a few drivers are blown in your speakers, since they're not working....although it would be good to test in other ways, but since the speaker partially works it sounds more like the speaker than the avr (the avr amp didn't likely just get picky about what frequency range it could power...).
post #7 of 18 Old 03-27-2013, 09:31 PM - Thread Starter
yeah thats what im starting to think. Its strange that its only powering the mids...makes no sense to me.
post #8 of 18 Old 03-27-2013, 09:33 PM
lovinthehd's Avatar
Liked: 4783
Could also be that the crossover network in the speaker could be an issue but you'd have to test each driver on it's own to find out...
post #9 of 18 Old 03-27-2013, 09:39 PM - Thread Starter
no idea how to do that, lol
post #10 of 18 Old 03-28-2013, 06:20 AM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Would it be possible to take it back to the dealer and have them hook each one to their receiver?
I'd have to agree that it sounds to me like there is an issue with the speakers, not the receiver.
audit13 is offline
post #11 of 18 Old 03-28-2013, 08:05 PM - Thread Starter
well i got them online so not really, may just have to ship them back, even though i tossed the boxes already :/
post #12 of 18 Old 03-28-2013, 08:26 PM
lovinthehd's Avatar
Liked: 4783
No friends that can help with swapping some gear around?
post #13 of 18 Old 03-29-2013, 03:15 AM - Thread Starter
possibly. I go to college out in the country, I live off campus, so dont know too many people. Ill ask around though!
post #14 of 18 Old 03-29-2013, 07:48 AM
Nethawk's Avatar
Liked: 119
I live near a college out in the country, where are you :-)
Are you certain the sound gave out only after turning them up? My first guess would be jumper between posts, and Mordaunt Short is picky about connection. Did you follow user guide or was that tossed out with box? :-D
Young Padawan, you have much to learn - always save the box for at least 30 days!
Nethawk is offline
post #15 of 18 Old 03-29-2013, 06:08 PM - Thread Starter
haha yeah i feel like an idiot for throwing the boxes out. i do still have the manuals and yes i did follow them. Im in virginia, in the mountains haha
post #16 of 18 Old 03-29-2013, 06:44 PM
Nethawk's Avatar
Liked: 119
^^ I'm in the mountains in Virginia too, about 20 minutes from UVA smile.gif
Nethawk is offline
post #17 of 18 Old 03-31-2013, 03:19 AM - Thread Starter
haha damn really? strange coincidence. Im in Ferrum, down by Roanoke
post #18 of 18 Old 04-02-2013, 11:08 AM - Thread Starter
UPDATE:
So I messed with the wiring today, I took out the banana plugs I had, and now the mids and lows work, but Im still getting no sound from the tweeters! Any ideas anyone?? Thanks for your help/suggestions!
Reply Speakers
