Jamo 700 compact - same as E700? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-28-2013, 10:51 AM - Thread Starter
Wolveres's Avatar
I just saw a pair of Jamo 700 compact speakers for 20 bucks. They sound good, and only have some minor cosmetic damage. I can't find anything on the model on the internet though. Only from the E700 series, which look slightly different, and have differing specs.
Can anyone tell me about their performance, and if they're worth it at 20 bucks?
Wolveres is offline
post #2 of 5 Old 03-28-2013, 11:50 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Pictures might help...
Afro GT
afrogt is offline
post #3 of 5 Old 03-28-2013, 12:36 PM - Thread Starter
Wolveres's Avatar
Wolveres is offline
post #4 of 5 Old 03-29-2013, 07:55 AM - Thread Starter
Wolveres's Avatar
Bump!
Wolveres is offline
post #5 of 5 Old 03-29-2013, 09:58 AM
afrogt's Avatar
Liked: 755
Well, as you can see by the pictures they're not the same speakers at all. The E700 has the woofer on top and tweeter on bottom.
If you've heard the Jamo 700 and think they sound good then of course they're worth $20.
You tried them out and like the sound so what's keeping you from making the purchase?
$20 for a pair of good sounding speakers is a no brainer.
Found this on ebay.
http://www.ebay.co.uk/itm/Jamo-Compact-700-Speakers-/200878711588?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item2ec54de324
Specs:
Long term power- 70w
Short term - 90w
Frequency range - 70-20.000hz
Impedance - 8 ohm
Size
Height 12"
Width 7.5"
Depth 8"
found specs here too.
MUSIC: - 90 W
NOM: - 70 W
IMPEDANCE: 8 OHM
Frequency response: 70 Hz - 20,000 Hz
Woofer: 6.5 "inches
Height - 30.5 cm.
WIDTH - 19 CM.
Depth - 21.5 cm.
Total weight - 5 kg.
MADE IN DENMARK
http://translate.google.com/translate?hl=en&sl=bg&u=http://www.hi-fi-zone.com/speakers/1502-jamo-compact-700.html&prev=/search%3Fq%3Djamo%2Bcompact%2B700%2Bspeakers%26start%3D20%26hl%3Den%26sa%3DN%26biw%3D1408%26bih%3D929&sa=X&ei=hbtVUcX6FKeaiAKjk4C4AQ&ved=0CEoQ7gEwAzgU
Afro GT
afrogt is offline
Reply Speakers
