Center Channel- Top or Bottom? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-29-2013, 10:12 AM - Thread Starter
Brad Sutliff's Avatar
So im rearranging some of my speakers for a better setup. I sit about 8 feet away from my 75ish inch screen. Would my center be better off below the screen? which is where i have it now. ( its about two or 3 feet below my ears) or above the screen? Im not totally sure the mount that came with it will allow me to angle it down or not though. Thanks
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #2 of 5 Old 03-29-2013, 10:34 AM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
picture says a 1000 words...can you provide one?
Afro GT
afrogt is online now
post #3 of 5 Old 03-29-2013, 10:46 AM - Thread Starter
Cant quite see where the center is, but the top of it is the small logo. this is taken from where i would be sitting
post #4 of 5 Old 03-29-2013, 11:58 AM
Bill Fitzmaurice's Avatar
Liked: 4695
In either case your visual cues will over-ride your audio cues and the sound will seem to come from the center of the screen. But having the source that far below your ears isn't good for high frequencies, which tend to travel in a straight line. In both cases you want the tweeter axis aimed at head level at the listening position.
Bill Fitzmaurice is online now
post #5 of 5 Old 03-29-2013, 11:59 AM - Thread Starter
ok so it would be best to have it above and angled at my head level?
Reply Speakers
