In-Wall Speaker Set-up, HELP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-29-2013, 11:34 PM - Thread Starter
drohde27's Avatar
Hello All,
New here as I am building my first theater room. I done framing and reading to run wires soon. The room is about 19'Lx16'W and 9' ceilings.
in advance and I look forward to exploring this site more.
I am about 99% sure I will be going with an epson 8350 projector.
However, I am lost when it comes to sound for the theater. I have seen a few polk package systems that seem ok, but I think they just wont deliver enough power to the room. I really dont know anything about sound or what to look for. The room will be used for mostly movies and sporting games, not much music.
Looking to keep it under $1650.
Thanks for the help and I look forward to reading more on the site in the future.
drohde27 is offline
post #2 of 7 Old 03-29-2013, 11:36 PM - Thread Starter
drohde27's Avatar
Sorry...forgot to say I am looking to buy in-wall and in-ceiling speaker. It would be great to get the center channel and maybe in the sub in-wall if possiable.
drohde27 is offline
post #3 of 7 Old 03-30-2013, 08:46 AM
BobL's Avatar
Liked: 56
Is your budget for just speakers and sub or does it include the receiver as well?
BobL is offline
post #4 of 7 Old 03-30-2013, 10:01 AM - Thread Starter
drohde27's Avatar
I have seen several receivers on discount at the stores around town, so the budget is really for speakers and sub. Seems I can get a good receiver for around 300bucks, depending on if its 5.1 or 7.1, etc.
drohde27 is offline
post #5 of 7 Old 03-30-2013, 11:28 AM - Thread Starter
drohde27's Avatar
I have been looking at putting 6 of these, Polk Audio RC85i. A Polk Audio Dual 5.25" Two-Way Center Channel In-Wall Speaker - 255c-RT..
This total I been quoted $725...
Review seem good for this set. However, not sure if I can mount one set on the ceiling or not. Also what sub would work best for set-up?
drohde27 is offline
post #6 of 7 Old 03-30-2013, 01:36 PM
flyingvfreak's Avatar
I would look to speakercraft and as far as polk ,also look to there RT vanishing series,there getting good reviews, have a good warranty. The 255 c,265 rt ,will make a good front stage & 65rt at the rears makes a nice matched set.
And with your walls open now is a good time to build chambers/back boxes,insulation..will improve sound and performance regardless what brand you go with.
For in wall subs ,your gonna have to spend a lot $$ at least a grand, a quality in wall /floor sub should come in its own chamber box and need a separate amp. Your better off with a active sub. You will get way more value and performance for your $$
flyingvfreak is offline
post #7 of 7 Old 03-30-2013, 06:31 PM
jugger's Avatar
Liked: 55
Here are some more options for you
http://www.klipsch.com/reference-architectural-speakers
RC-64 Center, RF-7 Fronts, RF-82 Sides, RW-12D, QTY=2, RSW-15, RS-52ii Rears, Pioneer SC-1522-K, Panasonic 65VT60, 65"
jugger is offline
Reply Speakers
