Sound card for Teufel E 400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-30-2013, 08:28 AM - Thread Starter
Dan Weatherley's Avatar
I have onboard sound and my motherboard is quite old as it is from a fairly old Dell PC. I am getting Teufel E 400 Digital. I have been looking at this: http://www.amazon.co.uk/dp/B0042RUEQW?tag=tesicai-21
I prefer using an external sound card as it is easier and I am a noob so i can't install it.
Will I hear a difference? I have not got the speakers yet.
Thanks all for help.
Dan Weatherley is offline
post #2 of 7 Old 03-30-2013, 02:14 PM - Thread Starter
Bump
post #3 of 7 Old 03-30-2013, 03:16 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Why don't you get the Edifier speakers you were looking at? It already has a DAC built in, no sound card needed, as long as your computer has optical out or coxial digital outputs. Or, if you don't have digital or optical out, then get a 2 channel DAC to go with the Edifiers. I've seen people over at head-fi.org (search there) say that the Hifimediy Sabre is a pretty good DAC, and it's not very expensive: http://www.ebay.co.uk/itm/Hifimediy-Sabre-USB-DAC-ES9023-Tenor-TE7022-96khz-24bit-96-24-/140911022146
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #4 of 7 Old 03-30-2013, 03:52 PM - Thread Starter
Thanks but I think I can't add DAC to the Edifiers for some reason...
I just read it somewhere.
Also I still have not decided on which speakers to get and I can't hear them in any shops because they are not mainstream frown.gif
post #5 of 7 Old 03-30-2013, 04:40 PM
cel4145's Avatar
Liked: 3002
Sure you can. An external sound card is a DAC that may have other features. With that DAC, you would need a 3.5mm to RCA adapter, and the plug it up to the back of the Edifier, which has RCA inputs. Look at the manual.
cel4145 is offline
post #6 of 7 Old 03-31-2013, 03:16 AM - Thread Starter
Ok thanks for your help, one last question, for £50 is that external sound card I linked worth it? smile.gif
post #7 of 7 Old 03-31-2013, 08:13 AM
cel4145's Avatar
Liked: 3002
Who knows? I don't, and apparently no one else who has read this post does, or they would have said something.
cel4145 is offline
Reply Speakers
