Soundbar hookup - Newbie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-30-2013, 09:34 PM - Thread Starter
jyeh74's Avatar
Hi everyone,
I am a newbie at audio. I purchased those new soundbars with HDMI connections. I want to connect my TV, to 2 boxes, one is cable box and one is PS3.
On the soundbar, there are
1) HDMI in - HDMI cord from soundbar to cable box.
2) HDMI out - HDMI cord from soundbar to the TV. HDMI port 1
So when I go to HDMI port 1, I get cable TV with the external sound from the soundbar.
How do I avoid switching the HDMI cable from the back of the cable box and plug into the PS3 every single time I want to play games vs watching TV? Do I buy a HDMI cable (plugged into HDMI in on the sound bar) that splits into 2 HDMI cables and put one to the cable box and one to the PS3?
If so, what happens when I am on HDMI port 1 and both cable box and PS3 are turned on? Which one will get the signal?
Probably been done before but its my first time setting this up. I think this sound bar is only set up for one specificed unit (cable box or blu ray player)
jyeh74 is offline
post #2 of 10 Old 03-31-2013, 06:34 AM
wronganswer's Avatar
Does the soundbar have an optical input?
wronganswer is offline
post #3 of 10 Old 03-31-2013, 12:39 PM - Thread Starter
jyeh74's Avatar
I see two additional ports
1) Optical In
2) Aux in
Not sure how that would connect to the PS3 though?
jyeh74 is offline
post #4 of 10 Old 03-31-2013, 12:42 PM
Ps3 to hdmi and cable box to optical.
post #5 of 10 Old 03-31-2013, 01:00 PM
Your cable box can send digital sound to the soundbar via optical cable
post #6 of 10 Old 03-31-2013, 03:36 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
ps3 hdmi to tv,
cablebox hdmi to tv,
tv optical to soundbar.
ifor is offline
post #7 of 10 Old 03-31-2013, 08:24 PM - Thread Starter
jyeh74's Avatar
Originally Posted by ifor View Post
ps3 hdmi to tv,
That works. HDMI for cablebox to TV. Another HDMI for PS3 to TV. Optical from soundbar to TV and now it works for all devices.
Then what is the point of having the "HDMI in" and "HDMI out" connections on the soundbar?
I can connect my laptop with a HDMI cable to the "HDMI in" on the soundbar to use it as speakers. But then there is no use for the "HDMI out" function
jyeh74 is offline
post #8 of 10 Old 04-01-2013, 08:55 AM
Connect the ps3 to hdmi in and your tv to hdmi out. You might get better sound with hdmi
post #9 of 10 Old 04-01-2013, 05:15 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Nope.
ifor is offline
post #10 of 10 Old 04-01-2013, 09:23 PM - Thread Starter
jyeh74's Avatar
Originally that is what I did, two HDMI cords from cablebox to soundbar and then to TV.
Sounds the same as the optical cable from the soundbar to the TV.
HDMI is for video and audio transfer.
I am not sure why there are "HDMI out" on the soundbar. I cannot figure out a use for it.
Maybe some TVs do not have optical outputs so they can only use HDMI? I don't know........,,
jyeh74 is offline
Reply Speakers
