Small speaker ideas for bedroom - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-02-2013, 08:17 PM - Thread Starter
rock324's Avatar
I'm mounting a 40-inch Bravia (KDL40EX640) on our bedroom wall. I've read that the sound on these tv's are pretty bad so I would like to look for some better options. The wife won't let me mount any speakers and it would have to be pretty small/discrete. I was thinking maybe a wireless speaker of some sort, but need ideas on where to put them. Also, do they make small, wireless soundboards or center channel speakers that I could put on our table under the tv? Looking to spend no more than $200, if possible. What are my options?
rock324 is offline
post #2 of 7 Old 04-02-2013, 08:24 PM
guteLaune's Avatar
I wish I had the perfect answer for you, but I really don't. Wireless and $200 are criteria that don't mix much. For the money, I think you're looking at a soundbar setup. For me, one of the best "TV speaker improvements" is a soundbar or a small, wall-mounted speaker/receiver combo, with the speakers mounted out pretty wide. I have some Martin Logan Motion 4's on my wall powered by a HK-3490...obviously the low end is lacking, but the clarity and overall depth of sound I get on movies is a HUGE jump from what my Panasonic ST-50 can do, and it's no slouch for a TV.
guteLaune is offline
post #3 of 7 Old 04-02-2013, 08:35 PM - Thread Starter
rock324's Avatar
Do they make wireless center speakers? Would they improve the sound? Not looking to get anything fancy....just somewhat of upgrade.
rock324 is offline
post #4 of 7 Old 04-02-2013, 09:03 PM - Thread Starter
rock324's Avatar
What about a pair of wireless speakers that I could put on ground behind bed or under nightstand?
rock324 is offline
post #5 of 7 Old 04-02-2013, 09:23 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
"Audioengine'"might have something for you. I purchased the A5's...(a little more money then you want to spend). I also purchased Audioengine"s wireless addaptor. Two small Powered speakers plugged in to the TV with a mini cable and you're in business.(volume knob is on the speaker). The wife can plug her smart phone or lap top in to the left speaker for Pandora or other digital music as well.
The speakers come with their own soft bag with a tie string, making them very portable and easy to repack back into their box for storage.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #6 of 7 Old 04-02-2013, 10:47 PM
sdg4vfx's Avatar
Quoted: 110 Post(s)
Liked: 151
+1
If the A5 pair is too large or too pricey the A2 pair might fit the bill - they cost $200. And I'm sure they would be a big improvement over the TV speakers wink.gif
sdg4vfx is offline
post #7 of 7 Old 04-03-2013, 07:58 AM
guteLaune's Avatar
Originally Posted by sdg4vfx View Post
+1
I agree these will sound better than TV speakers, but many TV's, when external speakers are connected, no longer allow you to control volume with the remote control. So, the OP would have to get up any time the volume needed adjusting.
Rock324, you mentioned putting these under the bed or somewhere else, just keep in mind, you'll probably want these speakers in the area of your TV, otherwise you'll be watching a show, but the sound will be coming from somewhere else (like under your bed, if you put speakers there).
Reply Speakers
