J logo speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-06-2013, 07:55 PM - Thread Starter
Chupacavra's Avatar
Hi,
New to the forum. Glad to be here. Hope all is well with everyone..smile.gif
Does anyone know the name of the manufacturer of the speakers int he pic? eek.gif[IMG
ALT=""]http://www.avsforum.com/content/type/61/id/186339/width/350/height/700[/IMG]
Chupacavra is offline
post #2 of 6 Old 04-06-2013, 08:00 PM - Thread Starter
Chupacavra's Avatar
speakerlogo.jpg 48k .jpg file
post #3 of 6 Old 04-06-2013, 08:05 PM
Bill Fitzmaurice's Avatar
Liked: 4744
Jensen.
Bill Fitzmaurice is online now
post #4 of 6 Old 04-06-2013, 08:09 PM - Thread Starter
Chupacavra's Avatar
OK!
Keepers? They sound ok. Model 5, Jensen
post #5 of 6 Old 04-06-2013, 08:18 PM
Liked: 4744
Originally Posted by Chupacavra View Post
OK!
Keepers?
So long as the woofer surrounds aren't toast.
post #6 of 6 Old 04-06-2013, 08:31 PM - Thread Starter
Chupacavra's Avatar
bouncy, they are!
Thank you.
10.00 and some sanding and teak oil. Will be fine for the patio.
From a JENSEN flyer 1969.
THE MODEL 5 SPEAKER SYSTEM
We designed the Model 5 system as a four speaker three-way system, to give you
greater range, flexibility and more balanced sound. We've included a 12" woofer,
two complementary 5" direct radiating mid-range elements, and our famous Sonodome Ultra-tweeter.
The unique design of this system incorporates our Total Energy Response, which
produces the best musical balance throughout your listening room.
We have used our trademarked, and justly famous foam Flexair suspension system,
to give sound clarity and realism. And our special crossover networks are designed
to provide optimum smoothness and tonal blend.
The woofer coil has four layers. There is a Tuned Isolation Chamber
an each mid-range speaker Our Sonodome Ultra-tweeter will respond beyond audible
ranges.
And there are two rear panel balance controls.
Model 5 has a luxurious hand rubbed walnut cabinet finished an four sides.
It may be positioned upright or an its side.
SPECIFICATIONS.
Frequency Range: 32-30,000 Hz
Power Rating: 60 watts
Impedance. 8 ohms
Crossover: 500/4,000 Hz
Dispersion: 170°
Dimensions: 26" x 15" x 13" deep
Balance Controls: Two, for mid and high frequencies
Grill Cloth: Easily removable brown and black patterned fabric
Connections: Push type binding posts
Shipping Weight: 52 lbs.
Reply Speakers
