Polk to B&W - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-08-2013, 04:10 AM - Thread Starter
Jogo's Avatar
Hello,
I can trade my polk RT55 to b&w 603 from 1999. Is this a good choice. Anybody experience ?
thx
Jogo is offline
post #2 of 10 Old 04-08-2013, 07:21 AM
ProfD's Avatar
Quoted: 25 Post(s)
You gotta listen to them and decide for yourself.
ProfD is offline
post #3 of 10 Old 04-08-2013, 07:36 AM - Thread Starter
Jogo's Avatar
ofcourse, i'am a little bit afraid of the lack of bass with the b&w with the passive woofer. anybody has experienced this ?
Jogo is offline
post #4 of 10 Old 04-08-2013, 07:40 AM
ProfD's Avatar
Quoted: 25 Post(s)
I have been listening to a pair of B&W 683s with a Klipsch RW-12d subwoofer. I pass all the bass below 80Hz to the subwoofer. It sounds great. I have no complaints about bass.
ProfD is offline
post #5 of 10 Old 04-08-2013, 09:35 AM - Thread Starter
Jogo's Avatar
is that an adjustment on your amplifier or subowoofer?
Jogo is offline
post #6 of 10 Old 04-08-2013, 10:31 AM
commsysman's Avatar
Quoted: 987 Post(s)
Liked: 526
The Stereophile test data on a later model of that speaker in 2005 showed the bass to be down 3db at 40 hz. You should look at that article at the Stereophile website.
That is very good bass response. The 7 inch woofer is not passive. Both it and the 7 inch midrange are directly driven.
Very few speakers go much lower, and even then one really needs a dedicated subwoofer for reproducing the really really low stuff, like large drums and low pipe organ notes.
Those speakers should be a huge upgrade from your current speakers if they are in good operating condition. The overall sound quality will be one heck of a lot better.
Buying used speakers of that vintage is a crapshoot unless you can actually listen to them at fairly high volume to verify their operating condition.
commsysman is offline
post #7 of 10 Old 04-08-2013, 10:54 AM
ProfD's Avatar
Quoted: 25 Post(s)
You make those adjustments on your AMP.
ProfD is offline
post #8 of 10 Old 04-08-2013, 11:49 AM
Ysay's Avatar
Totally agree with ProfD. I have a pair of old Polk RT55i and a pair of B&W 602 S3. Although I'm using the B&W right now on my HT, listening to the Polks in my garage still gives me the smile. If I have to get rid of one of them, I'll get rid of the B&W.
Ysay is offline
post #9 of 10 Old 04-08-2013, 12:15 PM - Thread Starter
Jogo's Avatar
So you prefer the polks?
I want to go to one brand. I front I have the RT55's, and in the back 2 B&W 601 dm's. Or I sell the polks and place B&W 603 towers.
Or I sell the B&W 601 dm's and place other little polks like rt25 ....
Jogo is offline
post #10 of 10 Old 04-08-2013, 12:52 PM
Ysay's Avatar
I prefer the Polk RT55i over the B&W 602 ..... Yes! They are both bookshelf of almost the same size. I don't know if I can say the same thing with the 603 though.
Ysay is offline
Reply Speakers
