instructions on what cables and what i need to hook up my speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-08-2013, 01:32 PM - Thread Starter
jaynoob's Avatar
cable connection.jpeg 134k .jpeg file a friend gave me 4 emerald em 97 mk IV speakers but without any cables ...
first of all i dont know what cable i need
second how am i supposed to hook them up to my vizio 42 in flat screen tv(i think its that size i forgot)
any and all help on hooking it up would be gratly appreciated thnx
Name:	cable connection.jpeg
jaynoob is offline
post #2 of 4 Old 04-08-2013, 02:06 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Is this TV running off a roof antenna, cable box or what?
(1) Audio visual receiver - minimum recommendation - http://www.accessories4less.com/make-a-store/item/ONKHTRC330/Onkyo-HT-RC330-5.1-CHANNEL-HOME-THEATER-RECEIVER/1.html#!reviews
(2) Speaker cable 14 gauge from hardware store, home improvement store or http://www.amazon.com/Cadence-14G152M-Red-20-Designed-Performance/dp/B00BJCPDJG/ref=pd_sim_sbs_e_1
arnyk is offline
post #3 of 4 Old 04-08-2013, 02:11 PM - Thread Starter
jaynoob's Avatar
cable connection.jpeg 134k .jpeg file right now the tv isnt hooked up to cable or antenna just to my xbox360 and xbox regular... i need that adio reciever box? and those are the cables i need right?
jaynoob is offline
post #4 of 4 Old 04-14-2013, 12:33 PM - Thread Starter
jaynoob's Avatar
okay i have the cables and the banana plugs i need... but what other plugs/cables am i supposed to use to actually hook up to that reciever you recommended? also the receiver u recomended says 60 watts per channel... my speakers say power handling 125 watts.. does that mean anything in specific?
jaynoob is offline
Reply Speakers
