help choose between two speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-09-2013, 06:14 AM - Thread Starter
milll36's Avatar
Hi im doing a bedroom system, i have already 2 jl audio f 112 subwoofers that im going to use on this system... so i need to decide speakers.:
M K SOUND S 150 MK II - I auditioned this setup and really liked the sound for movies , effects are amazing with this speakers, i know that isnt the original M & K but i really liked the sound.
Triad Silver LCR - I was able to audition GOLD LCR wich i also liked very neutral and natural speaker... and will go loud, but i didnt hear the silvers so really dont have much to compare.
this willl be run with 4520 and if needed an xpa 3 that i would upgrade from my other setup....
room is around 3000 cu ft.
Tks
milll36 is offline
post #2 of 3 Old 04-09-2013, 07:54 AM
gtengineer's Avatar
Sorry, did you say you are going to be using two JL F112 subwoofers, for a bedroom system?
This is going to be for movies mainly?
gtengineer is offline
post #3 of 3 Old 04-09-2013, 05:25 PM - Thread Starter
milll36's Avatar
Yes mainly movies, i have in my den other setup that i usually use for movies. Tks
Dan
milll36 is offline
Reply Speakers
