Which set is better for HT? - AVS Forum | Home Theater Discussions And Reviews
Old 04-13-2013, 01:34 PM - Thread Starter
cemo62's Avatar
Quoted: 48 Post(s)
Hello Friends
1st set PIONEER VSX-921 AV RECEIVER + PolK AUDIO TSI-400 KULE TIPI HOPARLOR +POLK AUDIO TSI-100 RAF TIPI HOPARLOR +POLK AUDIO CS-10 MERKEZ HOPARLOR
2nd set PIOneER VSX-921 AV RECEIVER+ KLIPSCH RF 42 II (CIFT)+KLIPSCH RS-42 II HOPARLÖR(arkaya) + KLIPSCH RC 42 II MERKEZ HOPARLOR
Can you please help me?
cemo62 is offline
Old 04-14-2013, 05:46 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The Klipsch will be better for HT.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 04-14-2013, 06:17 AM
wronganswer's Avatar
Polk RTi line is really good for home theater
wronganswer is offline
Old 04-14-2013, 06:25 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The Klipsch will do better because of its sensitivity and compression driver mated to the horn. It can get much louder with less power and handle the peak dynamics of a movie much better than a soft dome tweeter. With a claimed sensitivity of 96 db's will make much better use of your receiver's power. Although the Polk is no slouch at 91 dB's. Listen to both, see which you like better. Thats all that really matters anyway.
Old 04-14-2013, 06:56 AM
Badouri's Avatar
Liked: 56
Originally Posted by flyng_fool View Post
The Klipsch... With a claimed sensitivity of 96 db's...
Quote from Bill Fitzmaurice:
Originally Posted by Bill Fitzmaurice View Post
That's because it's not a 96dB sensitive speaker. They are posting a phony SPL spec that's based on the sensitivity of the horn loaded tweeter. Accurate SPL specs are based on the woofer sensitivity. With consumer grade woofers that will run between 85 and 90dB, with 87dB being the average. With dual woofers sensitivity can be between 88 and 93dB. Claims for more than that are BS, pure and simple. That includes Klipsch, who pull the same charade as BIC.
To get true high sensitivity the woofer must be horn loaded and/or it must be a high sensitivity pro-sound woofer. Klipsch Heritage products do have high sensitivity for that reason. If the woofer is a pro-sound woofer but not horn loaded its high sensitivity is realized at the cost of low end extension. So if you see a direct radiator woofer cab rated for 98dB with 40Hz extension it's probably a BS spec. If it's rated for 98dB with 70Hz extension then it's probably accurate.
Badouri is offline
Old 04-14-2013, 08:03 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Ok, that's fair. But do you believe the Polk 'speaker's claim on it's sensitivity? My guess would be that the two manufacturers list their claimed specs in a similar manner which still puts the Klipsch ahead for output. Once again, as I suggested earlier, the OP should go listen for himself and buy the one he likes better.
Old 04-14-2013, 08:22 AM
Bill Fitzmaurice's Avatar
Liked: 4630
At least it's not patently false.
Bill Fitzmaurice is online now
Old 04-14-2013, 09:08 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Is Klipsch well known for doing this?
Old 04-14-2013, 09:59 AM
colemad5's Avatar
Don't get caught up in the crap surrounding sensitivity and how it is measured. I have personally owned a set of Polk Monitor Series II and recently moved to the Klipsch Reference line and I will say definitively that the Klipsch speakers are much more detailed and fuller sounding with movies than the Polks. I have also noticed how much louder they get without distortion with movie cues such as explosions, gunfire, crashes, etc. One scene where I noticed this the most was the train wreck scene in Super 8. The polks had a bit of distortion in the sound where the Klipsch speakers brought it home with full force, loud and clear. I just don't want you to pass up on a nicer set of speakers because someone doesn't like how Klipsch markets their sensitivity.
colemad5 is online now
Old 04-14-2013, 11:27 AM
Badouri's Avatar
Liked: 56
Originally Posted by cemo62 View Post
Hello Friends
You don't mention a subwoofer? Details about the room?
Really different systems:
TSi400 Tower speaker with three 5-1/4 inch drivers.
CS10 Center channel speaker with dual 5 1/4-inch drivers.
TSi100 2-way bookshelf speaker with 5 1/4-inch driver.
RF-42 II Dual 4.5" (11.4cm) Cerametallic cone woofers
RC-42 II Dual 4" (10.2cm) Cerametallic cone woofers
RS-42 II Dual 4" (10.2cm) Cerametallic cone woofers (Dual 1" titanium horn-loaded tweeters)
Badouri is offline
Old 04-14-2013, 01:28 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
Hello Friends
Someone else mentioned the size of your room.
Knowing that would be helpful, along with why you have just these two choices and what your real budget is?
bladerunner6 is offline
Old 04-14-2013, 02:06 PM - Thread Starter
cemo62's Avatar
Quoted: 48 Post(s)
Sorry, room is 9,2 feet wide and 15 feet length. height to ceiling from floor is appx 9 feet
My budget is 2500 dolar, but i live in turkey so i dont have many choices and ht market is expensive here
ps: sorry for my english
cemo62 is offline
Old 04-14-2013, 02:23 PM
Liked: 4630
They're one of the worst offenders. And considering the unquestioned integrity of the man who's name the company carries on, it's a shame. If Paul Klipsch were alive today you wouldn't see them posting the specs that they do. PK championed the use of honest measurements. The current management doesn't post any charts to back up their claims. Of course, they can't, because their claims are, to quote Paul's favorite phrase, "BS". rolleyes.gif
Old 04-14-2013, 02:32 PM
Badouri's Avatar
Liked: 56
Do you have a subwoofer?
Badouri is offline
Old 04-14-2013, 11:26 PM - Thread Starter
cemo62's Avatar
Quoted: 48 Post(s)
No but i would like to have, i dont have experiences about speakers etc
cemo62 is offline
Old 04-15-2013, 06:41 AM
Badouri's Avatar
Liked: 56
You should buy bookshelf speakers for front left-right + a subwoofer instead of buying tower speakers.
The Klipsch system you listed needs a subwoofer, the small drivers offer limited performance.
You can check what bookshelf speakers and subwoofers are available in your price range and make us a list.
Not sure you understand what i mean so i will give you an example with speakers from your list:
4 POLK AUDIO TSI-100
1 POLK AUDIO CS-10
1 POLK AUDIO DSWPRO660wi
Make a list of bookshelf speakers and subwoofers that are available in your price range.
Badouri is offline
