$800 Budget. Help me choose my AVR and 5.1 Speakers. Please? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 04-19-2013, 12:49 PM - Thread Starter
jordandrako's Avatar
So, I'm finally getting to the point in my life where I can start using equipment that isn't from goodwill or garage sales and would like to buy a 5.1 setup for my living room (apartments for now). With a new HDTV, my old speakers look and sound weak. I'm currently using a Philips blu-ray home theater system that I got for less than $300 so this is going to be a huge improvement, I don't think I need the $2000+ setups I see around the internet as that'd pay for a semester of college. I've got a budget of $800 (I'd like to go lower if possible) and need an AVR and 5.1 speakers. I don't care if they're different brands, but I'd prefer towers over satellites for the fronts, and the backs need to be mountable.
I can increase my budget, as long as the speakers come separately so I can buy over time.
So far, with my research I've found a few options.
AVRs:
Yamaha RX-v573
Good choice because 7.1 and brand new.
Denon 1612 Refurbished
Nice option for saving money, but nervous about the refurb bit.
Denon 1913 Refurbished
Refurb still make me nervous, but this it a nice balance between the two above. Top choice at the moment.
Speakers
Pioneer Andrew Jones 5.0 speakers w/ bookshelf speaker wall mounts
Klipsch sub-12 synergy. Wife wants down firing sub for looks. Is there a better down firing sub for $300?
Wiring
Wire
http://www.amazon.com/Mediabridge-Gauge-Speaker-Wire-Feet/dp/B0044YPN0A/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1WZZH58BPHWW1&coliid=I13YJWPO3K41R5
Plugs
http://www.amazon.com/Monoprice-109436-High-Quality-Copper-Speaker/dp/B0097JLQVC/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1WZZH58BPHWW1&coliid=I11L6Z73UP7LUO
Thanks for all the help so far.
jordandrako is offline
post #2 of 20 Old 04-20-2013, 09:14 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Check out the Andrew Jones Pioneer speakers. Here's a review:
http://www.audioholics.com/reviews/speakers/floorstanding/pioneer-sp-pk52fs
Then wait and get a better sub later on.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #3 of 20 Old 04-20-2013, 09:44 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1 on the Andrew Jones Pioneer speakers - at that price point they simply cannot be beat. The msrp for the 5.0 is just under $500, but you can often find some or all of the speakers on sale at either BestBuy or Fry's.
Also, for that budget you might consider these less expensive AVRs ...
This Denon 1612 for $199 would work fine for you - http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html.
If you really want to add AirPlay then for $220 you can get the Denon 1613 - http://www.accessories4less.com/make-a-store/item/DENAVR1613/DENON-AVR-1613-5.1ch-Networking-Receiver-w/AirPlay-3D-ready/1.html.
Both those AVRs will handle 3D, have network connectivity and include Audyssey MultEQ room correction.
The go-to budget HT sub most often recommended in the forums is the Klipsch RW12D, which can often be purchased on sale for $300. If you don't want to grow the budget at the moment, you could always add this sub later.
sdg4vfx is offline
post #4 of 20 Old 04-21-2013, 05:11 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
AVRs:
Yamaha RX-v573
http://www.amazon.com/Yamaha-RX-V573-7-1-Channel-Network-Receiver/dp/B007JF861O/ref=cm_cr_pr_product_top
This will leave me room to get more speakers down the road if I get more space. Ethernet is nice too.
Sony STR-DH540
http://www.amazon.com/Sony-STR-DH540-Channel-Receiver-Black/dp/B00BHC7ZT4
This one doesn't seem as good, but is cheaper which will leave a bit better budget for speakers.
Speakers
Energy 5.1 Take Classic
http://www.amazon.com/Energy-Classic-Theater-System-Black/dp/B001202C44
The reviews sound solid, but they're satellites so I know they wont pack the same sound towers can.
Then there's buying monitors and subs separately, which I have no clue about.
Wiring
Wire
Plugs
I know I'm asking for a lot, and this budget wouldn't be terrible if I didn't need a receiver as well, so it's below beginner audiophile budget, but it'll be enough for me until I have to upgrade my TV in 10 years. So have I picked out the best for my small budget or is there something I'm missing? I'm heading over to Listen Up later today so I can listen to a few systems myself, but I'd like to get some input from you guys, since you seem to know more than most employees do at audio stores (who are likely getting payed to boast certain brands). Any help would be greatly appreciated.
How big is your room?
I am wondering if towers are the best option?
bladerunner6 is offline
post #5 of 20 Old 04-21-2013, 10:01 AM - Thread Starter
Thanks for the suggestions!
My living room is currently about 13'x11'. Kinda tiny, and my neighbors won't necessarily enjoy my speakers, but my wife only wants to buy this once. Meaning that when we upgrade to a bigger apartment this year, and we're saving up for a house (we'll have enough in 2-3 years) I'll still be using this system. Hopefully for the next 10 or so years, preferably longer.
My idea was to extend my budget, but also buy over time so it's not a huge cost all at once. I was thinking buy an AVR now and splice my current speakers to use it, then replace my current satellites with the Energy Take 5.0 system, then get the Klipsch sub-12 (wife wants down firing for looks), then either inherit my late uncles towers (he had a several thousand $ setup, which my grandma doesn't know how to run) or buy polk audio tsi300 towers and move the Energy satellites to the side. After all that I'd end up with a 7.1 setup costing about $1300 (less if I can get my uncles old towers) but it would be over a couple months or years.
I'll look into those cheaper AVRs and the Pioneer speakers as well. But since my couch is against the wall, should I not get the bookshelf speakers and get mountable satellites for the surrounds?
And should I worry about those being refurbished, or is Denon good about that? I don't have any Apple products, I don't believe in supporting terrible company practices, so I don't need airplay, but is there any other benefit to having ethernet on the AVR?
Just a bit more info, the devices I need to connect are:
blu ray
Xbox 360
PC
Next console, either PS4 or Xbox 720. These will have a blu ray drive so I can get rid of the blu ray for this.
It will be used for roughly 45% games, 20% TV shows, 20% music, and 15% movies.
post #6 of 20 Old 04-21-2013, 10:16 AM
kingpin748's Avatar
I suggest saving up more money but failing that you should consider a Monoprice.com setup. Go browse the site, they got cables and everything.
kingpin748 is offline
post #7 of 20 Old 04-21-2013, 10:29 AM
commsysman's Avatar
Quoted: 970 Post(s)
Liked: 522
IMO the Energy Take speakers are a joke. The front speakers have main drivers that are the same size as the speaker in a cheap clock radio.
For $800, you can do a lot better.
You can get a much better receiver, the Harman-Kardon 1650, for under $400, and IMO it is MUCH better than anything else at that price (much better amplifiers and power supply IMO).
I would never recommend a Sony or Yamaha receiver to anyone. IMO they are the worst ones on the market.
The Jamo S426 HCS 3 system is probably the perfect speaker system for you.
It is a 5.0 system with tower speakers, and Amazon has it at the incredibly low price of $179 right now. It has sold in the past at $300-400.
I would jump on that deal quickly.
commsysman is offline
post #8 of 20 Old 04-21-2013, 10:42 AM
cel4145's Avatar
Liked: 2991
Might want to take another look at that receiver. Seems like HK has changed their design with their more recent receivers. That 1650 only weighs 9.1 lbs, which does not bode well for the quality of the power supply and output of the amp eek.gif
Moreover, unless things have changed, I've never seen good reviews of the HK room correction software, which is an important feature. Perhaps it has improved?
post #9 of 20 Old 04-21-2013, 10:44 AM
bullpuss's Avatar
Liked: 65
The Martin-Logan MLT-2 system has better speakers all around, especially the sub. Don't worry about the bass affecting the neighbors, because you can turn down the subwoofer as much as needed,
depending on the circumstances. You should be able to get it for well under $400 also.
I agree with you about the speakers, but i am partial to the Denon as the receiver. Denon sound quality is top notch in my opinion..............they lack certain outputs on the lower end receiver.
bullpuss is offline
post #10 of 20 Old 04-21-2013, 10:51 AM - Thread Starter
Great input. I've updated the topic post with my preferred choices so far.
post #11 of 20 Old 04-21-2013, 10:52 AM
commsysman's Avatar
Quoted: 970 Post(s)
Liked: 522
You are seriously confused on the weight of the 1650.
It weighs 9.1 KILOGRAMS, WHICH IS 21 POUNDS!! (Check the PDF -owner's manual)
(shipping weight 25 pounds)
LOL
post #12 of 20 Old 04-21-2013, 10:57 AM
cel4145's Avatar
Liked: 2991
They say on their website that it is 9.1 lbs:
So I'm not the one that is confused. HK obviously is.
post #13 of 20 Old 04-21-2013, 11:02 AM - Thread Starter
How is the HK 1650 compared to the Denon 1912?
post #14 of 20 Old 04-21-2013, 11:04 AM
commsysman's Avatar
Quoted: 970 Post(s)
Liked: 522
The Amazon website and the Harman-Kardon 1650 owner's manual both say 9.1 KG and 21 pounds, so you obviously were misled by a misprint.
I don't think ANY receiver weighs much less than 15 pounds, so any reasonably intelligent person would have checked further before believing a ridiculous number like 9.1 pounds (or repeating it).
post #15 of 20 Old 04-21-2013, 11:06 AM
commsysman's Avatar
Quoted: 970 Post(s)
Liked: 522
I like the HK better, but you are not going to go wrong with either one.
They are both better IMO than the Pioneer, Yamaha, or Sony AVRs for similar prices.
post #16 of 20 Old 04-21-2013, 11:16 AM - Thread Starter
How about the Denon 1913 $320 vs Onkyo TX-NR515 $220
What's the better deal.
post #17 of 20 Old 04-21-2013, 11:26 AM
Quoted: 20 Post(s)
Liked: 59
blu ray
Xbox 360
PC
For your current space, buy some decent bookshelf speakers, then convert them into surrounds later.
Some Polks, Infinities or Pioneer speakers on sale would all be good choices.
How much of that $1300 total do you want to spend right now? Are you sticking to $800? And also would you mind getting a sub later versus sooner?
post #18 of 20 Old 04-21-2013, 11:36 AM
cel4145's Avatar
Liked: 2991
Really? After the tirade you went on this past week about someone else having a history of insulting and nasty posting, you want to make personal attacks in this thread? Why not eat your own dog food and restrain yourself? rolleyes.gif
Amazon probably has some little office worker that pulls information from vendor materials. So citing their specs in a discussion is typically not very helpful. They have been known to be wrong.
But 9.2kg does convert to 20 lbs, so more likely that is the case.
post #19 of 20 Old 04-21-2013, 11:40 AM - Thread Starter
post #20 of 20 Old 04-21-2013, 12:30 PM - Thread Starter
I found these mounts http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-MS56B/dp/B000X9O8SI/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=3BB581EHBM1M7&coliid=INKX4UN5FR0ZP
so I think I'll go ahead and go with the pioneer bookshelf speakers for surrounds. Does the $140 price include two speakers or just one?
Reply Speakers
