Thinking about changing it up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-19-2013, 03:06 PM - Thread Starter
Mk3_wagen's Avatar
Quoted: 179 Post(s)
I currently have the current setup:
2- Jamo C607
1- Jamo C60 center
2- Jamo C60 surrounds
1- Jamo SUB 650
1- Pioneer VSX-33 receiver
I just picked up a Pioneer SC-1522k and was thinking about changing the speakers. I like the Jamos and have yet to hook them up to the 1522k to see how they sound. If I went with new speakers the budget would be $2500 max including the sub. Is there anything out there within my budget that would sound noticeably better? I use my speakers mostly for movies, gaming, and TV if that helps.
TIA
Mk3_wagen is offline
post #2 of 15 Old 04-19-2013, 03:13 PM
SimpleTheater's Avatar
Quoted: 205 Post(s)
Liked: 96
Paradigm Studio 20's (3 across the front), with surrounds and a PDR12 sub.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
post #3 of 15 Old 04-19-2013, 09:42 PM - Thread Starter
Mk3_wagen's Avatar
Quoted: 179 Post(s)
Thanks for the suggestion.
Anyone like the Polk TSi series?
post #4 of 15 Old 04-19-2013, 09:58 PM
wronganswer's Avatar
Polk RTi's are better than TSi's.
wronganswer is offline
post #5 of 15 Old 04-19-2013, 10:01 PM - Thread Starter
Mk3_wagen's Avatar
Quoted: 179 Post(s)
Yeah I know, but those would probably need an external amp to sound good wouldn't they? I'm looking to just use the Pioneer SC-1522K to power them.
post #6 of 15 Old 04-19-2013, 10:08 PM
That Pioneer is a beast. You dont need an external amp.
post #7 of 15 Old 04-23-2013, 06:53 PM - Thread Starter
Mk3_wagen's Avatar
Quoted: 179 Post(s)
I was checking out the following:
2- Polk RTiA7
1- Polk CSiA6
2- Polk F/XiA6
1- Power Sound Audio XV15
Thoughts?
post #8 of 15 Old 04-24-2013, 11:20 AM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
2- Jamo C607
1- Jamo C60 center
1- Jamo SUB 650
I just picked up a Pioneer SC-1522k and was thinking about changing the speakers. I like the Jamos and have yet to hook them up to the 1522k to see how they sound.. If I went with new speakers the budget would be $2500 max including the sub. Is there anything out there within my budget that would sound noticeably better? I use my speakers mostly for movies, gaming, and TV if that helps.
TIA
Why don't you listen to the Jamo's with your new receiver? They may sound good enough for you to keep them. I don't understand why you're considering replacing them since you haven't tried them with the SC-1522?
Sounds like to me that you just have the itch to spend some money.
I wouldn't replace the Jamo's with the Polk Tsi speakers. Probably not the RTi either. But speaker preference is subjective.
Afro GT
afrogt is offline
post #9 of 15 Old 04-24-2013, 11:52 AM - Thread Starter
Mk3_wagen's Avatar
Quoted: 179 Post(s)
I wasn't planning on replacing them originally, but my new media room does not allow me to place the C60 surround at a 20 degree position as recommended by Jamo. Since they are dipoles I don't think they will sound good against the back wall which is 6-7 behind my listening area. That is kind of the reason I was looking at the Polks since they are dipole/bipole. The room I'm putting everything in is 16.5x13.5.
post #10 of 15 Old 04-24-2013, 04:48 PM - Thread Starter
Mk3_wagen's Avatar
Quoted: 179 Post(s)
Any other suggestions?
post #11 of 15 Old 04-24-2013, 06:10 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
I would go with something like Ascends or KEF Qs long before I went with Polks, even the Rti line. The PSA sub is going to be good though.
shadyJ is offline
post #12 of 15 Old 04-25-2013, 10:22 AM - Thread Starter
Mk3_wagen's Avatar
Quoted: 179 Post(s)
I've looked at the Ascend 340's and 170's, but I really want some bipoles since I want to mount them directly on the rear wall. I know I can buy stands or wall mounts, but I hate the way bookshelves look. I just want a clean look. I can get the Polk setup for less than $1300 shipped so I'm not sure if there's anything else out there in that price range that includes bipoles.
post #13 of 15 Old 04-25-2013, 01:03 PM
shadyJ's Avatar
Liked: 1352
You don't need the surround speakers to match your front stage speakers, it doesn't make a big difference in the sound.
shadyJ is offline
post #14 of 15 Old 04-25-2013, 01:11 PM
Nethawk's Avatar
Liked: 119
For HT this is true, but if multi-channel audio is a means of entertaining yourself I'd get something that closely matches the front soundstage.
Nethawk is offline
post #15 of 15 Old 04-25-2013, 01:56 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
+1
Even without multi-channel music listening, there is still some benefit. Just not nearly as critical as matching the front sound stage.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
Reply Speakers
