bi-amp 5.1 vs 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 04-19-2013, 05:35 PM - Thread Starter
weezz's Avatar
im still kinda new to this forum
so this question has probably been asked
my apologizes ahead of time
can someone explain the pros and cons of the bi-amp function on my rx-v867
i have a 7.2 setup with presence speakers
but it seems that in order to use the bi-amp mode i have sacrifice the my back surrounds and presence sp
and convert to 5.1 to use it
will bi-amping make a huge difference on my front sp???
is my speakers capable of doing well without that function or not???
i love the presence sp function because i can lift the dialogue from the center to the presence (it makes certain low dialogue more clearer)
i dont really want to turn that function off but it seems i cant use presence and bi-amp together right???
my current setup
RX-V867
yamaha NS-555 towerspeakers
yamaha NS-C444 center speaker
yamaha NS-333 for presence
sony SA-VE367T for surrounds speakers
SVS 20-39PCI
Yamaha YST-SW315
I know that i said much but any help will be appreciated thx!!!!
weezz is offline
post #2 of 27 Old 04-19-2013, 06:08 PM
DreamWarrior's Avatar
Quoted: 320 Post(s)
Liked: 238
Don't bother bi-amping, it's a waste of two amplifier channels in the opinion of just about everyone on here. The single case where I would even remotely think it useful is if you wanted to run a tube amp up top and a solid state down bottom because you want your highs to have that "tube feel".
That said, depending on your room size, many would discount 7.1, but if you already bought the speakers.... I still don't think there is much content with 7 discrete channels, so it's all matrixed. With larger rooms that really need the ambient fill, it's probably very helpful. In smaller rooms, it may hurt more than it helps....
That said...listen for yourself and see.
DreamWarrior is offline
post #3 of 27 Old 04-19-2013, 06:08 PM
virii01's Avatar
Technically it's bi-wiring. Your speakers are capable of that but it won't make a difference plus you'd lose your presence channel.
virii01 is offline
post #4 of 27 Old 04-19-2013, 06:10 PM
Petden's Avatar
Liked: 33
Proper bi-amping is done with 2 separate amps. The point of bi-amping or tri amping is to power the High frequency, mid frequency and low frequency drivers separately. Look at powered speakers. They quote a HF power and a LF power. This means that One amp is only providing power to either the HF or LF. This process, as far as I'm aware, uses active crossovers to separate the power. Im sure someone else could give you a much better example and a more in depth explanation.
Petden is offline
post #5 of 27 Old 04-19-2013, 06:16 PM
Bond 007's Avatar
Quoted: 2370 Post(s)
Liked: 1906
AVR biamping is a gimmick. Dont waste your time. The only way to get any benefit from biamping is to disable the crossovers in your speakers. As long as the crossovers in your speakers are active you will get no benefit. Even proper biamping usually has little effect on home speakers. It is something more relevant to concert live performance type speakers.
Licence to Kill
Bond 007 is online now
post #6 of 27 Old 04-19-2013, 06:21 PM
Quoted: 320 Post(s)
Liked: 238
If you mean, "even if you remove the passive x-over, using an active x-over and separate amplifiers still has little effect on home speakers" then I would only agree a little. Sometimes, having a lot more control over that active x-over can have benefit to controlling how the drivers blend and mix with the room. So, if you have a powerful enough active x-over / processing system, it may help. Otherwise, probably not.... And I suppose, still, there would probably be things (room treatment) better done first before reaching into that territory anyway for that last percent.
Of course, if you don't remove the passive x-over, I wouldn't ever put an active x-over in front...you'll probably do more harm than good having the two slopes compete.
post #7 of 27 Old 04-19-2013, 07:25 PM - Thread Starter
weezz's Avatar
wow
I'm overwhelmed with everone on point responses
looks like ima need to learn more about hometheater speakers and receivers lol
ok so it seems the bi-amp function is not that that useful
my yamaha manual states that it will produce higher quality sound....??? (paraphasing alil)
I guess my NS-555 are good on there own huh???
and yea I like my presence sp
my dialouge is alil more spacious than centered
any more replies
greatly appreciated!!!
weezz is offline
post #8 of 27 Old 04-20-2013, 07:02 AM
Bill Fitzmaurice's Avatar
Liked: 4628
my yamaha manual states that it will produce higher quality sound....???!!
Manuals are written by marketeers, not engineers. So-called passive bi-amping does nothing, neither does bi-wiring. Manufacturers include those options so that they won't lose a sale to someone who's been convinced that they do work.
Bill Fitzmaurice is online now
post #9 of 27 Old 04-20-2013, 09:45 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
wow
any more replies
Since you have all this equipment why not just try it? If you hear a difference, leave them that way. If not change it back to the original configuration.
You've got nothing to lose but a little time.
Afro GT
afrogt is offline
post #10 of 27 Old 04-20-2013, 12:24 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1037
Are you looking for more power? Just add an amp. As long as you have preouts, not sure of your AVR. There are affordable Behringer amps out there for a for a few hundred.
Reefdvr27 is offline
post #11 of 27 Old 04-20-2013, 12:38 PM
genesplitter's Avatar
Quoted: 29 Post(s)
Liked: 25
Here is a really great article explaining the benefits of bi-amping, and why bi-wiring (bi-amping and keeping the passive crossover) is a gimmick - http://sound.westhost.com/bi-amp.htm#common-question
Marantz SR-7009 AVR, iNuke 6000DSP, DIY LinkwitzLab speakers, MartyCube + JohnnySub, BenQ W1070, Roku stick, Plex, next project: diy AT spandex screen
genesplitter is offline
post #12 of 27 Old 04-20-2013, 03:34 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
Exactly. At one place I worked, the engineers laughed at the things the marketing people put in the manuals.
At another company, the marketing people asked the engineers to review and redline the manuals before the final copy. Sometimes the changes would be made, and sometimes they wouldn't be made.
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #13 of 27 Old 04-20-2013, 03:35 PM - Thread Starter
weezz's Avatar
so far i notice some difference but small
on bi-amp mode i notice my bass had a lil stronger punch and treble was alil tighter from the ns-333 towerspeakers
on non bi-amp with presence speakers functioning everything sound more EXPANSIVE and clear
difference is small.....!!!!
weezz is offline
post #14 of 27 Old 04-20-2013, 03:39 PM
yelnatsch517's Avatar
What is more funny is that most people believe the marketers as opposed to the engineers.
Funny how this world works right?
If there's one thing I've learned it's that as long as you know how to talk, people will believe anything you say. Even if it's pure crap.
yelnatsch517 is offline
post #15 of 27 Old 04-20-2013, 03:42 PM - Thread Starter
weezz's Avatar
really thats weird and funny
maybe if the AV companies explained more on passive bi-amp instead of saying "higher quality sound can be achieved though bi-amp" (or something like that) people like me (but still learning more on this) wouldnt be so confused on this
right??? lmao smh
weezz is offline
post #16 of 27 Old 04-20-2013, 03:43 PM - Thread Starter
weezz's Avatar
thx will read!!!!
weezz is offline
post #17 of 27 Old 04-20-2013, 03:45 PM - Thread Starter
weezz's Avatar
i spent so much thus far on my home theather....smh lol that thought never crossed my mind
will look into that thx
weezz is offline
post #18 of 27 Old 04-20-2013, 03:50 PM
Hahaha, that chart made me laugh.
If I'm looking at that correctly, marketing/sales have the worst ears, followed by professional reviewers. The best untrained ears are from audio retailers?
Hahahaha!
So much for "golden ears" lol.
post #19 of 27 Old 04-20-2013, 03:51 PM - Thread Starter
weezz's Avatar
really
thats is not good
i would assume that the manual would be written by engineers (or anybody else that help made them )that had made the receivers instead of marketeers???
shame on the marketeers lol smh
weezz is offline
post #20 of 27 Old 04-20-2013, 03:53 PM - Thread Starter
weezz's Avatar
Hahahaha!
dam smh im speechless for a sec lol
weezz is offline
post #21 of 27 Old 04-20-2013, 03:55 PM - Thread Starter
weezz's Avatar
has anybody tried the bi-amp mode on your receivers???
tell me your experiences
even if it is small
weezz is offline
post #22 of 27 Old 04-20-2013, 04:03 PM
Bond 007's Avatar
Liked: 1906
My honest experience before I got wise. I tried biwire first with no noticeable difference. Then I tried biamp with no noticeable difference. Now I have my towers biwired because Im too lazy to change it and Im running front heights. Big difference and I love it.
Licence to Kill
post #23 of 27 Old 04-20-2013, 05:33 PM - Thread Starter
weezz's Avatar
yup that what i noticed when i turned my bi-amp on and bi-wired my speakers
my highs and lows were alil more noticeable but at the cost of losing presence lol
weezz is offline
post #24 of 27 Old 04-20-2013, 05:55 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
I'm pretty sure he meant his front heights is what made a big difference not his biwiring, biamping.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #25 of 27 Old 04-20-2013, 06:37 PM
Bond 007's Avatar
Liked: 1906
Correct.
Licence to Kill
post #26 of 27 Old 04-20-2013, 09:06 PM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
I tried mine, too. No real difference and then left them bi-wired because I was also lazy smile.gif
However, I bet those front heights DO make a good difference.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #27 of 27 Old 04-21-2013, 01:26 AM - Thread Starter
weezz's Avatar
opps
i did misunderstood that.....opps
lol
but now i get it!!!! thx
weezz is offline
Reply Speakers
