Speaker Recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-20-2013, 02:02 PM - Thread Starter
stilly's Avatar
Living in Canada my speaker selections are limited. I've owned Polk Rti and LsiM speakers, Klipsch Rf 82's, and just sold my Def Tech Mythos ST's. I'm looking for some speaker recommendations in the $2500 range just for the front speakers. The centre and surrounds will follow suit. Definitely want towers for the fronts. Do 50/50 on movies and music.
Will be driving them with a Onkyo per amp and 200 watt per channel x5 amp.
The speakers will find there place in our new home currently being built and will have a dedicated theatre room, sound proofed and all( 13'6 x 29' x 8'8 high.
I have had a look at Axiom (M80), SVS ultra towers which seemed nice but has mixed reviews.
Any help would be appreciative.
stilly is offline
post #2 of 7 Old 04-20-2013, 02:46 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Why not check out the Paradigm Studio 100 v5? They have received excellent reviews.
audit13 is offline
post #3 of 7 Old 04-20-2013, 02:57 PM - Thread Starter
stilly's Avatar
Those would be nice but they are close to $4k a pair. Over what I wanted to spend
stilly is offline
post #4 of 7 Old 04-20-2013, 04:11 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
A dedicated theater room? I would be looking at some speakers with real dynamic range. I would go for some Pi Fours with the upgraded drivers or some JTR Noesis 228HTs. Those will get you some honest to god THX Reference levels. No full range tower speaker with a conventional tweeter is going to be able to do that, or even get close. The only problem is these speakers will need a real subwoofer to keep up with them, and a serious sub isn't going to be cheap (unless you can DIY). But if you are getting a dedicated room, you should be getting a serious subwoofer system anyway. Another speaker to look at, however a chunk over your budget, is the JBL LSR6332 speakers- those are high output reference monitors that studios use to create their soundtracks. As such, they are very high performers with a THX pm3 certification, which is not an easy standard of performance to achieve. A tremendously good value for 1600 each.
shadyJ is offline
post #5 of 7 Old 04-20-2013, 09:10 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Yeah. I think the SVS Ultra speakers would definitely be worth exploring. They have a distributor in Canada, so you get good pricing: http://www.sonicboomaudio.com/speakers-systems-ultra-speakers-c-13_28.html
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #6 of 7 Old 04-20-2013, 10:53 PM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 194 Post(s)
Liked: 219
I would also recommend looking as SVS as they make great products. Another two speakers I would look at are NHT and PSB. They both make great speakers at good prices. PSB's are made in Canada.
NHT Fours:
http://www.nhthifi.com/Four_Left?sc=12&category=3773
Specifications
System type - Tower speaker (left side)
Configuration - 4-way hybrid acoustic suspension /bass reflex
Woofer – 1 x 10"" anodized aluminum cone woofer
Lower Midrange - 1 x 6.5" anodized aluminum cone, long throw design
Midrange - 2” anodized aluminum dome midrange
Tweeter - ¾” anodized aluminum dome tweeter
Cabinet Material - 30mm MDF front baffle, 25mm bottom, all others and internal braces 18mm
Power Handling - 250W
Frequency Response - 27Hz-20kHz.
Crossover Frequency - 125 Hz, 800 Hz, 3.2kHz
Crossover Slopes - 12dB LP, 12dB HP 12dB LP, 12dB HP, 18dB LP, 18dB HP.
Sensitivity - 86dB
Impedance - 6 ohms nominal
Inputs – 4 each nickel plated 5-way binding posts with “jumper” straps for b-amp/bi-wire
Dimensions - 41"H x 7.5"W (13.5" W to outside of edge of base) x 16"D
Weight - 64.3 lbs/29.2 each
Shipping weight - 80 lbs./36.3 kg each
Finish - Piano high gloss black multi-coat painted finish with 2 acrylic clear coats
Sold - individually as a left or right speaker
PSB:
http://www.psbspeakers.com/products/tower-speakers/Imagine-T2-Tower
General
Enclosure Bass Reflex
Finish Lacquer
Color Gloss Black
Tweeter Dome
Tweeter Size (inches) 1
Midrange Size (inches) ---
Woofer Size (inches) 5.25
Woofer Composition Ceramic/Poly
Woofer Surround Rubber
Built-in Powered Sub No
Video-Shielded Yes
Connector Type Post
Bi-amp Inputs Yes
Parts Warranty 5 Years
Labor Warranty 5 Years
Specifications
Power Range 20-200
Frequency Response 38-23k Hz
Sensitivity 90 dB
Impedance (Ohms) 4
Amplifier Power ---
Height (inches) 37-1/8
Width (inches) 7-1/2
Depth (inches) 13-3/4
Weight 40.6 lbs
Ray
"Listen with an open heart and mind."
cavchameleon is offline
post #7 of 7 Old 04-21-2013, 08:50 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Sorry, I should have said Studo 60, not 100.
The 60s have a list price of $2700.
audit13 is offline
Reply Speakers
