First home theater setup (and thoughts on Pioneer) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-21-2013, 06:31 PM - Thread Starter
dustin200183's Avatar
I am setting up my very first home theater, and I have been looking all over for speaker advice. I am completely new at this (only 6 months ago I was still rocking a 27" CRT), but I finally decided on the setup below, which comes to $1001.80 on Amazon (I'll hunt for better prices after all the decisions are final)
Pioneer SP-PK52FS system (minus the included sub)
BIC America F12 sub
Denon AVR-1613
I found almost universal praise for all of these components everywhere I went (CNET, The Wirecutter, Audioholics, Reddit's /r/hometheater, etc.), and the AVS forums was the last place I was going to check. To my surprise, I have found many threads that strongly criticize the Pioneers.
I understand that for $1000 I'm not going to get an audioholics dream build, but is there a vastly better build to be had for around this price point? Most threads I saw suggested building up to a 5.1 system and hence buying more expensive components slowly over time, and while I understand fully the benefits of this, I would really really like to buy a complete setup at one time. I'll be mostly watching movies, as well as some music, in a medium sized room.
dustin200183 is offline
post #2 of 8 Old 04-21-2013, 07:20 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
Hey don't worry, those items are all well regarded here. I'd suggest you change to a Denon 1713, as it has the better Audyssey if I am not mistaken for the few $$ difference.
Personally I would choose the Harmon Kardon 1650 (95W/ch) over a 80W/chan Denon. I like Denon a lot, but I would much have more power when running tower speakers.
The Pioneers have gotten pretty rave reviews here as far as I've seen. I personally wasn't too thrilled with them when I tried them but it was at BBY in a far far far from ideal area to listen. I felt I had to crank the volume before they got going. I would have to listen to them in a home before I criticized any further.
AVR: Marantz 7008 Phono: Pro-Ject Debut III Speakers: BW CMC2 + 2xCM9 (front) + 2xCM5 (rear)
TV: Panasonic 65ZT60, Samsung 60F5300
skidawgz is offline
post #3 of 8 Old 04-21-2013, 09:14 PM
sdg4vfx's Avatar
Quoted: 118 Post(s)
Liked: 153
How big is your room/space?
How far away is the seating position?
Ratio of music/movies/tv listening?
sdg4vfx is offline
post #4 of 8 Old 04-21-2013, 09:27 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Yes. The Pioneer speakers and BIC F12 are probably the best 5.1 combination you could get for that price. Good choice smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #5 of 8 Old 04-21-2013, 09:33 PM
cel4145's Avatar
Liked: 3002
I wouldn't bet on the HK 1650 being better. Could easily be worse.
The HK 1700 (100 watts/channel) didn't test out that well with all channels driven
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 32.8 watts
1% distortion at 39.5 watts
On the other hand, the predecessor of the Denon 1613, the 1612, did just fine
0.1% distortion at 71.5 watts
1% distortion at 79.8 watts
Meanwhile, the HK 3450 (much higher model) didn't fare that much better than the Denon 1612:
0.1% distortion at 70.4 watts
1% distortion at 85.8 watts
cel4145 is offline
post #6 of 8 Old 04-21-2013, 09:47 PM
csgamer's Avatar
Liked: 29
Good luck finding a speaker with no critics, doesn't exist. When you find one, preferably one that I don't have to sell my home to own, then let me know, so I can end my speaker searching/upgraditus. With any speaker you will have people who don't like it for whatever reason. Some people even prefer bloated muddy bass and some like in your face highs. Everybody is different.
csgamer is offline
post #7 of 8 Old 04-21-2013, 10:59 PM
Dan Hitchman's Avatar
Quoted: 3559 Post(s)
Liked: 1903
BIC America F12 sub
Denon AVR-1613
Your insights serve you well. This is the best advice you could get. Get a receiver and a pair of higher quality left and right speakers and then plug 'n' play as you save up. Stick to the same speaker model line you chose (except the sub, which can come from any manufacturer, as long as they're good, of course). Subwoofers are chosen usually by room size and bass requirements of the listener.
Too often somebody will want it all right away and then end up not being completely satisfied... and turn around and upgrade again soon after, especially if their budget is tight.
The Pioneers are good for the money... but there are better speakers out there if you just give it some thought and time.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #8 of 8 Old 04-22-2013, 08:48 AM
sdg4vfx's Avatar
Quoted: 118 Post(s)
Liked: 153
+1
sdg4vfx is offline
Reply Speakers
