Swap front speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-23-2013, 06:24 PM - Thread Starter
airalex's Avatar
Here's my situation. I am currently using Polk Monitor 70s for my front left and right and a Polk CS20 as my center. A friend of mine has a pair of Boston Acoustics RS334 for his left and right as well as the Boston Acoustics RS260 bookshelf speaker as a center. He hasn't used this setup in a while so it's in his basement storage just collecting dust. His wife wants to do some spring cleaning so he's offering to just give it to me. Is it worth it to switch from my current setup to his?
airalex is offline
post #2 of 5 Old 04-23-2013, 06:31 PM
swim33's Avatar
Well, I would go ahead and take them. Bring them home and set them up next to yours and see how they sound. If you like them, just replace yours with his and use your polks as surrounds. If you don't like them you could use them as surrounds or just offer to give them back or come up with some idea for them.
-Ben
swim33 is offline
post #3 of 5 Old 04-23-2013, 06:35 PM - Thread Starter
airalex's Avatar
Good idea, that is probably the best solution. Only problem is the drive isn't exactly close so I'd hate to do it more than once.
airalex is offline
post #4 of 5 Old 04-23-2013, 06:54 PM
swim33's Avatar
Well if it's far then just don't take them back once you have them wink.gif find some other use for them.
-Ben
swim33 is offline
post #5 of 5 Old 04-24-2013, 06:42 AM - Thread Starter
airalex's Avatar
Anyone know how the BAs sound?
airalex is offline
Reply Speakers
