Rubber padding For Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-25-2013, 12:55 AM - Thread Starter
marvelousmarvyd's Avatar
Hey Guys,
I'm trying to find some self adhesive rubber padding that arefairly thick that I can stick on the bottom of my speakers but won't damage the finish and leave a lot of gooey residue when removed, Any suggestions? Trying to cut down on the vibrations.the speakers are causing.
marvelousmarvyd is offline
post #2 of 6 Old 04-25-2013, 01:21 AM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Grip shelf liner
Mrkazador is offline
post #3 of 6 Old 04-25-2013, 02:28 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Blu Tack. Available at Home Despot
ifor is offline
post #4 of 6 Old 04-25-2013, 07:37 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Cut some of this to size, a bit smaller than the speaker so that it won't be obvious:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=202015909&R=202015909#.UP66YGeYUYc
It's not adhesive, but it doesn't need to be.
Bill Fitzmaurice is online now
post #5 of 6 Old 04-25-2013, 09:41 AM - Thread Starter
Thanks guys I will look into that apache mat, never thought about going to home depot. I'll look around there and lowes to see what each has.
post #6 of 6 Old 04-25-2013, 10:52 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
There is a product that is PERFECT for that.
It is sold at RV stores such as Camping World to line the shelves in motor homes and camping trailers to keep things from sliding around on the road.
It usually comes in a roll about 10 inches wide and is a sort of a waffle-pattern tacky rubber matting about 1/4 inch thick, which is only half that thick with weight on it.
You can easily cut it to fit with scissors.
Originally Posted by marvelousmarvyd View Post
Hey Guys,
commsysman is offline
Reply Speakers
