Any advice on good speaker stands for my new acquisition: Q300? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-25-2013, 02:40 PM - Thread Starter
krishn82's Avatar
I tried calling the folks at KEF Direct and all they'd tell me is that I could try Sanus or Bell'O. But given the size of the speakers, I'm looking for something that has a substantial enough platform on which the speaker can safely sit and not tip over. If any of you has purchased stands for Q300 that you're happy with, I'd greatly appreciate a tip. Thank you!!!!smile.gif
krishn82 is offline
post #2 of 5 Old 04-25-2013, 08:32 PM
havok2022's Avatar
I have some older Q series and I have both Sanus and Bell'O stands. Unless you get silly with the stands AND speakers, the risk of tipping is always there. That said, a heavy stable stand should be fine. Of the ones I own (or have owned) I prefer the Sanus Steel Foundations. Sturdy, heavy, can be filled with shot if wanted, and reasonably priced. I have the Natural Foundations, and they eventually broke at the base. The top end Sanus stands are awesome, but very expensive. Look at the Steel Foundations imo.
http://www.sanus.com/us/en/products/speaker-foundations/sp-steel/
Unless you want their best....
http://www.sanus.com/us/en/products/speaker-foundations/sp-ultimate/
LG 55EC9300 - MartinLogan Ethos - MartinLogan Motif X - B&W 685 S2 - B&W AWS610 - Anthem AVM60 - Parasound A31 - Parasound Zamp v3 - Oppo UDP-203
havok2022 is offline
post #3 of 5 Old 04-25-2013, 10:32 PM
rjhart00's Avatar
I just bought some of these in black for my new Aperion Verus Grand Bookshelfs from adorama for $60.
http://www.sanus.com/us/en/products/speaker-foundations/sp-natural
I just got them in the other day and am satisfied with the purchase.
rjhart00 is offline
post #4 of 5 Old 04-26-2013, 12:13 PM - Thread Starter
krishn82's Avatar
Thank you! I got Sanus stands as well. Just nervous about stability. Going to try it with BlueTac. If it doesn't work, back in the hunt!!!
krishn82 is offline
post #5 of 5 Old 04-26-2013, 12:15 PM - Thread Starter
krishn82's Avatar
Yep, these are the exact ones I got. Let's see how they play out. Thanks!
krishn82 is offline
Reply Speakers
