Which combo set up is better?only polk user and lover..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 04-28-2013, 12:11 PM - Thread Starter
Sagar7877's Avatar
which one is better combo?room 14*18...distance from front speaker 10-12 ft.....reciver yamaha rx v 671 90watt 8 ohm...
1) rtiA3(Front)
csiA6(center)
tsi100(surround)
DSW550 pro
2)rtiA5(Front)
csiA4(center)
tsi100(surround)
PSW125
Can't afford dsw series woofer and A6 with A5....only go for that if my front isA3..2 nd system does cost little more....but will 2nd system is better...movies 60%music 40%...thanks
another 3rd option is there.....
3) rtiA5(Front)
csiA6(center)
tsi100(surround)
in that case..can't really affoard any subwoofer now..in near future..probably 1 years later..dsw550/psw125....but in 10-12 ft distance will A6 gonna make any huge difference than A4?
Sagar7877 is offline
post #2 of 33 Old 04-28-2013, 12:17 PM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
What is your MAX speaker budget?
There are better options than Polk.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #3 of 33 Old 04-28-2013, 12:27 PM - Thread Starter
Sagar7877's Avatar
actaully I already have tsi100 from polk..which will go ti surround...so I am leaning towards polk...
post #4 of 33 Old 04-28-2013, 04:32 PM
macfan's Avatar
Quoted: 23 Post(s)
Liked: 43
HUH? There are? You could never convince me of that. I love my Polks. Each to their own I guess. That is why they make both chocolate and vanilla.
macfan is offline
post #5 of 33 Old 04-28-2013, 04:43 PM
XStanleyX's Avatar
Liked: 1269
I'd go with option 3 and start saving for a better sub. You'll survive without a sub for awhile and be happier in the end.
XStanleyX is offline
post #6 of 33 Old 04-28-2013, 04:44 PM
Badouri's Avatar
Liked: 56
1) rtiA3(Front)
csiA6(center)
tsi100(surround)
DSW550 pro
2)rtiA5(Front)
csiA4(center)
tsi100(surround)
PSW125
3) rtiA5(Front)
csiA6(center)
tsi100(surround)
I would go with option 1 but i would choose another sub. How much are you paying for the DSW550 pro?
Badouri is offline
post #7 of 33 Old 04-28-2013, 04:51 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
if you have a frys near buy you can pickt up on some polk rti line speakers for cheap. rti12 for 299.00 each! those will have plenty of bass until you can afford s better sub.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #8 of 33 Old 04-28-2013, 09:06 PM - Thread Starter
Sagar7877's Avatar
I am from India..there are not much option for subwoofer..no BIC..only yamaha,polk..not even klip....so have go for dsw pro 550.......I am confused 90 watt is enough for rti A5?will they work nicely?will I get massive difference in sound quality in that wattage among rti A3 and RTi A5?
post #9 of 33 Old 04-28-2013, 09:47 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
yes 90 watts will drive those speakers fine since they are fairly sensitive @90db.
that means 1 watt will produce 90db sound and doubling the amp power will increase output 3db
2watts=93db
4=96
8=99
16=102
32=105
64=108
128=111
256=115
post #10 of 33 Old 04-28-2013, 10:24 PM - Thread Starter
Sagar7877's Avatar
not only the loudness...I mean to say soundspace and clarity...I will buy dsw 550 later ..and then only upper frequency of 80Hz will be payed by RTiA5.So..in a 18*14 room...10-12 ft listening distance from front speaker..A3 or A5?
post #11 of 33 Old 04-28-2013, 11:17 PM - Thread Starter
Sagar7877's Avatar
also..noty much space for A6..if I go for A4..will that be o k ..with A5....alos..listening distance is 10ft..so A6 probably to bright..
post #12 of 33 Old 04-29-2013, 05:43 AM
Badouri's Avatar
Liked: 56
You are wasting your money with the RTiA5 if set to small with a 80Hz crossover setting.
CSiA6 does not sound "brighter" than CSiA4.
Badouri is offline
post #13 of 33 Old 04-29-2013, 07:30 AM - Thread Starter
Sagar7877's Avatar
I mena to say..because distance is so little 10ft..probably A4 will be sufficient..also...what crossover should I fix with rti A5 in front?or if I add sub woofer dsw 550 that can go 23hz in low..in that case will I need rti A5?or rti A3 will sufficient?
post #14 of 33 Old 04-29-2013, 07:59 AM
Badouri's Avatar
Liked: 56
I would buy RTiA3 and DSWpro550
Badouri is offline
post #15 of 33 Old 04-29-2013, 10:06 AM
kevon27's Avatar
Quoted: 149 Post(s)
Liked: 163
And how do you define better? Speaker sound quality is a subjective thing.
kevon27 is offline
post #16 of 33 Old 04-29-2013, 12:23 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
nevermind him, he says that in every thread across the board.
post #17 of 33 Old 04-29-2013, 12:30 PM
butterlord's Avatar
Why do you say that? I thought small would be the appropriate setting for these since they don't go *that* low. And what would be an ideal crossover for a set up like this?
butterlord is offline
post #18 of 33 Old 04-29-2013, 01:05 PM
Liked: 1766
Not thin sounding, as in more full, dynamic, punchy, louder with less distortion, more realistic recreation of instruments and vocals, etc. etc.
post #19 of 33 Old 04-29-2013, 02:43 PM
Badouri's Avatar
Liked: 56
Did you read the whole thread?
Badouri is offline
post #20 of 33 Old 04-29-2013, 04:22 PM
butterlord's Avatar
Yes. Would a simple explanation or expansion of your advice be so out of the question? Not everyone has the same knowledge level as you, and just reading "x is so stupid." without anything further is unhelpful. Spread the knowledge, right?
post #21 of 33 Old 04-29-2013, 08:09 PM - Thread Starter
Sagar7877's Avatar
lol....still did not get the answear ..for rti A5 what crossover frequency?and rti A5 can be driven by 671 properly?
post #22 of 33 Old 04-29-2013, 08:38 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you have a subwoofer you can generally set the crossover to 80hz for your front speakers. you can also try 60hz if you'd like. just experiment and see which way you like better.
The yamaha 671 should have no problem with the Polk speakers, especially since you have a powered sub handling the low frequencies.
Afro GT
afrogt is online now
post #23 of 33 Old 04-29-2013, 09:15 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
What expired crack are you smoking? When did it ever make a comment like that?
Wrong person dude.
i was telling you to nevermind Dan Hitchman....I take it comprehension is not your strong suit?
post #24 of 33 Old 04-29-2013, 09:19 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
the 671 will drive the a5's fine, what more do you need to know? My 773 drives my A7's past reference levels cleanly. set crossover to 60-80hz as mentioned above, or you might try leaving them set large/full range.
post #25 of 33 Old 04-30-2013, 06:07 AM
Badouri's Avatar
Liked: 56
Does the Yamaha RX-V671 have a global crossover setting? (same for all speakers) If so, you need to consider all speakers in the system.
Badouri is offline
post #26 of 33 Old 04-30-2013, 07:42 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
yes it does...one crossover setting applies to all speakers.
post #27 of 33 Old 04-30-2013, 08:40 AM
kevon27's Avatar
Quoted: 149 Post(s)
Liked: 163
Okay.. I apologize for jumping the gun..
kevon27 is offline
post #28 of 33 Old 05-01-2013, 07:20 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
No problem! we all misread things at times and I am by no means perfect. But yea you will see Dan hates Polk. He knocks them in every thread Polk is mentioned.
post #29 of 33 Old 05-01-2013, 08:28 AM - Thread Starter
Sagar7877's Avatar
I made my mind.it will be rti A5..little confused about center...will A4 be enough?or should I go for A6?10ft distance (only) , little space and 90watt (little power) rx-v 671 pushing me towards A4.But extra space and bucks if really pays differnece I will go for A6...any thought???
post #30 of 33 Old 05-01-2013, 08:37 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
here is my setup:
yamaha 773
Polk rti-a7 fronts
csi-a4 center
rti-4 surrounds
Dual Power Sound Audio XV15 subs
The yamaha drives these speakers to reference levels 105db+ with ease @ 15.8ft. the a4 center is plenty! i listed a chart of how much power it takes to drive 90db sensitive speakers vs spl with little to no distortion. the sound is clean crisp and has a excellent soundstage.
Reply Speakers
