Surround speakers orientation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-30-2013, 07:56 AM - Thread Starter
JDErickson84088's Avatar
Quoted: 21 Post(s)
I have read lots of threads about this but can't seem to find a consensus.
Should surround speakers be facing forwards into the room or facing each other (both orientations are above ear height in the room listed below).
JDErickson84088 is offline
post #2 of 2 Old 04-30-2013, 08:46 AM
flickhtguru's Avatar
Liked: 111
For 5.1 surrounds are side speakers so they should be on the side walls facing into the MLP.
For 7.1 surrounds are the same as 5.1 but you also add surround backs which mount on the rear wall facing forward.
Here is a link to help you out.
http://www.dolby.com/us/en/consumer/setup/connection-guide/home-theater-speaker-guide/index.html?onlnk=cl-sc
Shawn
flickhtguru is offline
Reply Speakers
